Question about OKI MICROLINE 520 Matrix Printer
How do you replace an okidata microline 521 printhead?
    Problem Solver:
  • 8 Answers
Turn the printer off
remove the ribbon
on the right side of the head you will see a silver lever/tab lift up on that it is hinged on the left side
lift head straight out
reinstall in reverse order
Posted on May 08, 2009
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320- having menu problems
Menu Light flashing is a printhead thermister overheat problem.
Power off the printer and try reseating the print head; if this fails you'll need to replace the print head!
Nov 21, 2008 | Matrix Okidata Microline 320 Printer
Printhead needs replacing
The printhead is completely user replaceable and need no complicated instructions.
1. Remove the ink ribbon.
2. Looking from above, find a small shiny lever to the right of the printhead.
3. Lift the lever with your hand and remove the printhead by pulling it upwards (make sure the printer is cold).
4. Reverse the procedure to install the new printhead.
Be blessed.
Oct 31, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320Turbo 9pin
The problem your having is with the carriage assembly. You'll need to remove the ribbon and printhead. It's the black piece under them. Here's a link to a replacement part for $38.95.
http://www.str-s.com/okidata-turbo-carriage-assembly-p-716.html?manufacturers_id=6&osCsid=8849c8b4
Hope that helps you. :o)
Oct 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 521
You should clean the printer every six months (or after
about 300 hours of operation).
1. Turn the printer OFF.
2. Remove the paper from the path.
3. Open the access cover and remove the pull-up roller
assembly.
4. Use a clean, dry cloth to dust the area around the
carriage shaft and platen. Be sure to remove any loose
particles of paper.
5. Reinstall the pull-up roller assembly.
6. Close the access cover.
Never use solvents or strong detergents on the
cabinet — they could damage the housing.
Aug 11, 2008 | OKI MICROLINE 521 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
651 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
SiNnA
SiNnA
Level 1 Expert
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
