Nikon Coolpix S210 Digital Camera Logo
Posted on Feb 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon CoolPix s3100 won't turn on, battery fully charged
I got my camera about a year and a half ago and hadn't used it in about 5 months. Now it won't turn on, I've plugged the camera in and also tried using a battery charger, which says that the battery has a full charge. I would like to be able to use my camera, please help.
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Feb 13, 2013
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390479
Points
6614
Replace the battery.
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Sep 02, 2008
SOURCE: Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Anonymous
  • 5 Answers
  • Posted on Dec 25, 2009
SOURCE: Charged Battery, Half Symbol!
maybe the batteries are old? i had this problem once. i just bought new ones.
Anonymous
  • Posted on Feb 25, 2011
SOURCE: I bought my nikon coolpix
I lost my CoolpixS3000 wall charger. Where can I get a replacement?
  • 102366 Answers
  • Posted on Apr 05, 2011
SOURCE: I'm trying to download pictures from my Nikon
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Anonymous
  • Posted on Jan 08, 2012
SOURCE: Bought a Nikon Coolpix S3000
Try the following:
- Remove and insert the battery (to reset)
- Start your coolpix
- During a few seconds, it shoud start... before saying the battery is low. Quickly connect it to a computer during that time (quite short !)
The problem occurs when the "charge by computer" option is activated (see user manual item #173 / page 161).
If the light flashes again, do not press the on/off button: instead, wait for the battery to get charged (otherwise everything will get stopped - and you will have to play again).
When done, check the "charge by computer" option (and fix it if misconfigured).
Iloilo city
try a different battery or use an external charger.... the battery could be faulty, or the camera charge function could be faulty.... a different battery will help you decide where the problem is.
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
5helpful
My Nikon Coolpix S3100 won't turn on
I had the same problem, and many other people have had this issue. The camera sat for too long, and the battery fully discharged. It needs to be reset. In order to do that, remove the battery and memory card. Replace only the battery, and plug it in. You should see a green light flashing to the right of the LCD screen. That means it is now charging. Replace your memory card, and let it charge before trying to use it.
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
2helpful
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
