Question about Zenith R57W46 57" Rear Projection Television
Doubling tv is doubling, and color is off. seeing two of everything...
  • Zenith Master
  • 8,617 Answers
You can get the convergence repair kit to repair that problem at this link. The kit contains both ICs and the feed resistors, and also has instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/zenith-r50w46-r57w46-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 02, 2009
3 Suggested Answers
Boba
  • 64 Answers
SOURCE: Seeing double on our Pioneer SD-533HD5
The convergence IC's need to be replaced. look for stk letters and some numbers on them. If You are familiar with electronics repair try replacing them but be careful there is high voltage in the set even after unpluging it from the wall. Post back
Posted on Nov 13, 2006
SD Tech
  • 14553 Answers
SOURCE: the colors on my tv are seperated you see double
This is a set first made in 2001---if colors are skewed and will not adjust in the customer mode (convergence) you have a convergence circuit problem.
This set uses two of the STK-392-150 convergence IC chips--both need to be replaced and the set adjusted. Sometimes there will be either a fuse or resistor around them that is bad--for the most part just both chips need to be replaced.
Most shops get 300 or more for this repair but you can buy a pair of chips on EBAY for under 14 dollars plus shipping.
If you or someone you know can do it I can tell you everything you will need to do it and give general instructions on how to get at the chips and replace them.
Here is a picture of a similar model with the same problem:
a5a0f2c.jpg Not all sets with this problem look exactly the same.
This photo was provided to me by a customer who I repaired the set for and shows a typical convergence problem in this type of TV.
If this information has helped you rate this solution as I do this here for free.
If you want to know where to get the parts and also what is needed for the repair---let me know and I will post the needed items first and the instructions also.
SD TECH
Posted on Dec 10, 2009
I have a double picture and no color on my 19" RCA Model # led19b30rq tv. How can this be fixed
check your single with a nouther tv to see if it working to see if you have single or a color pic this is a lcd tv ?
Nov 20, 2013 | RCA Televison & Video
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
Picture is in showing in double vision with colors serperated
bulb is going out. go back to where you bought it to see if warranty will cover it. if not, buy another bulb. ours was like, 40 bucks.
Apr 26, 2009 | Televison & Video
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
JVC 56" projection tv
Replace STKs in convergence board.
Oct 17, 2008 | JVC HD-56FB97 HDTV
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Im seeing double on my 36inch Mitsubishi projection!
Do the colors seem "separated" somehow?  Sounds like the projectors might have become misaligned. Has the TV been knocked by pets/children/spouse?
Nov 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
197 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
