Question about Samsung VR8460 VHS/S-VHS playback VCR
My Samsung video cassette recorder (VR8460 or VR5460) is giving error message SAFE. Can you help me clear it? It will not power off. I have not tried unplugging yet.
Hi. I don't know if you have solved this problenm yet, but that isn't an error. Just press Display button about 5 seconds and that's all. It's just a safety feature to avoid someone from changing setup whet it's prepared to timer record.
Posted on Mar 16, 2010
    Genius:
  • 1,148 Answers
CHECK THE MENU
Posted on May 15, 2009
What is a record error: Codec error Samsung camera
Update the firmware to obtain the correct codec
Dec 22, 2015 | Samsung Video Cameras
My GO-VIDEO model GV-4060/GV-4600 dual-deck video cassette recorder has a on-screen display message that says "ERROR". I have turned the power "off" then back "on" to clear...
The loading deck is out of sequence Check to see that the loader is in the correct position. reset & it should work properly
Nov 30, 2010 | Televison & Video
Re-insert the cassette error message
SMACK THE CAMERA ON EITHER SIDE REAL HARD
? what does it mean plz?
can you explain for me plz?!!
Apr 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Partial static in playback and record even after head cleaning
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
Mar 16, 2007 | Sony Handycam CCD-TR517 Camcorder
Protection! Flashes on screen
This camera has a history of the flexible harness located on the cassette housing tearing when it rubs against the frame as the housing moves in and out. The harness tears and opens the circuit that detects the tapes record lockout tab, the camera is preventing you from recording on the tape in error. This repair requires replacemnent of the cassette housing, not for the faint of heart. I wish you luck. Joe Weibel customelectronics.org
Feb 04, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung VR8460 VHS/S-VHS playback VCR Logo
211 people viewed this question
Henry  Thomas
Henry Thomas
