Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
Netgear wndr3300 5.0 ghz range
The netgear dual band rangemax router is supposed to have 10x the range with the 5.0 ghz channel, but it cant even reach the floor above. Is there any software error that could be occuring? and if not, what could be causing the problem?
  • davidhgei Feb 02, 2009
    Well the router we had before was a linksys g router from 3-4 years ago. But I don't understand why the 5.0 ghz transmitter wouldn't go as far as the 2.4 ghz transmitter (both are coming from the same router, not the old one).
    Thank you for your help so far, I appreciate all the help I can get.
  • Russ Andrews
    Russ Andrews May 11, 2010
    OK...I verified this at:
    http://kbserver.netgear.com/datasheets/e...
    Before you flame me...the 5.o Ghz is the transmitting frequency of the device...as opposed to the 2.4 ghz transmitting freq of the more common ones. The problem with the 2.4 ghz has been that other devices including wireless phones have been using same channel. This is what the 5.0 ghz is supposed to change.
    While you device is using Dual Transmitters...the signal still weakens going through objects...like the floor...or walls...or doors...
    Is this the first wireless in the house, or have ou had a precious one? Did that one have trouble going upstairs? Have you tried relocating the router to a different spot? Let us know...
  • 854 Answers
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
Note: Name (11N SSID) is for wireless N computers running at 5GHz and the Name (11G SSID) is for wireless G computers running 2.4GHz. Kindly make sure that (11N SSID) and (11G SSID) names are different.
c. Set the mode to Up to 270Mbps at 5GHz & 54Mbps at 2.4GHz.
d. Set the 11N Channel to 48 / 5.240GHz and 11G channel to 1 / 2.412GHz.
e. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
6. Connect wireless computer to the router.
Note: If your wireless computer supports 5GHz and 2.4GHz frequency you will see two wireless networks which are 11N and 11G SSID. However, if your wireless computer only support 2.4GHz frequency you will only see one wireless network which is 11G SSID.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet with the ideal speed you have from your ISP.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Who is your internet service provider? Is it Cable or DSL connection?
2. How many wired and wireless computers are connected to the router?
Posted on Jun 02, 2009
Netgear 3300 does it work as a wireless repeater?
http://reviews.cnet.com/routers/netgear-wndr3300-rangemax-dual/4505-3319_7-32863752.html
sounds like that router isn't really well liked.
I do not recommend using wireless repeaters because your "second" network is only as good as the uplink to it, and I find you often can't move the repeater too far from the first router without sacraficing a lot of quality.
plus that router has bad range to start from what I hear
Oct 14, 2012 | NetGear WNDR3300 - RangeMax Dual Band...
I currently have an AT&T Fast Access DSL modem/router and want to add a netgear wireless N router to boost the range. What's the easiest way to do this?
The best possible configuration will be to configure the netgear router as an access point.
The following link will be useful:-
http://kb.netgear.com/app/answers/detail/a_id/965/kw/Configure%20router%20as%20AP/r_id/100109
Nov 10, 2009 | NetGear RangeMax Dual-Band Wireless-N...
My Netgear Rangemax WND3300 has been working fine for 1 year, but in the past 2 days the 2.4 GHz wireless signal has been cutting in and out every 30 seconds, making it impossible to use my laptop. I...
Well, There seems to be an issue with the wireless network on 2.4 Ghz band. Please change the wireless channel on 2.4 Ghz to a diffrent value and check if works fine.
Let me know if you need any further help.
Oct 20, 2009 | NetGear RangeMax WPN824 Router
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Where do I find the WPA key for my new Netgear RangeMax Dual BAND Wireless-N Router?
A WPA ket is a password that you create. If you didnt create one, you shouldnt have one. If one is set and you dont remember, reset the router to factory settings.
Dec 29, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
XBox 360
It is running on a differently frequency.
Dec 23, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
How do I port forward my router (netgear dual range -N- wireless)
You log into your netgear and under firewall you add the port exception to the list.
If you need additional help tell me the model of your netgear router.
Regards
Dec 18, 2008 | NetGear RangeMax Dual-Band Wireless-N...
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
2,242 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
