Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Replacing the LCD battery on a Panafax UF-885
I am getting an error message of "Replace Battery Info code =026" on my Panafax UF-885. Where is the battery located and how do I replace it? Is there a specific battery or part number for this LCD battery? It's just a backup in case of a power outage.
    Genius:
  • 2,120 Answers
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Posted on Feb 02, 2009
You will see a white Plastic tab sticking out of the black base under the lcd screen part of the base
Push FIRMLY towards the side with your thumb.
Posted on Nov 03, 2012
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 low battery on display how do you change the battery and what size is it and where is it
Pull up and open the doc feeder. Push the large white tab hanging down towards the rear to release the battery holder....it's hard to do.
The battery is a CR-2032 available anywhere.
If there is no white tab to push, somebody has lost the battery holder.
Oct 08, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
LCD Display too faint
Replacing the battery won't change anything.The LCD would have to be replaced, there are not any adjustments to change the LCD intensity.
Jun 08, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
649 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
