Question about Asko 1595 Dishwasher
Automatic detergent dispenser does not
The model # is FDB126RBS2
  • 8 more comments
  • jwebb40 Feb 02, 2009
    ive added dishwasher cleaner and and twice and still have soap on dishes im thinking the door is opening to late ?
    every thing looks clean and there is lots of water
    i pulled the spray bar out and looks great i triped the door latch turned on unit and water flew out 5 feet
    could timer be bad it stop starts and drys fine
    ok i have removed it and it also turned freely it pulls out very easy and all holes are large and seam open
    its a Frigidaire the door will not open at what point should the door
    open
    the door was open in the past I have tried both high end and low end soap the last soap i tried was some eco friendly soap that left a scum and ive been trying to clean it out and thats when i noticed the soap door not opening .running it now and the soap door opened about half way point on the timer before dry cycle right now im useing a walmart soap and its geting better but door did not always open
    should i just get a new spray bar
    the soap door opened about 15 or so after the mark were it says light wash its past the half way on the timer and seems to be doing a rinse cycle ill let you know how long that last
    thank you all for your help ill keep check back and keep you posted
    President:
  • 1,214 Answers
Make sure all the spray bars are rotating good, that there is no trash in the spray bars or plugged nozzles, and that the pump inlet screen at the bottom of the dishwasher is not plugged up.
The dispenser works on water spraying on the cover.
If all the above doesn't fix it, then replace the dispenser.
Reply what you find and I'll help further.
Posted on Feb 02, 2009
  • 5 more comments
  • Mark Egan Feb 02, 2009
    You need to check the spray bars and make sure all is working correct there.
    Spraying water is what opens the door. If the water spray is sluggish, then your right, the door opens during the rinse cycle, leaving soap on the dishes.
    You need to manually reach in and try to rotate the upper and lower spray bars. They should turn very freely.
    Then, you need to check that the nozzles are clear, and it's best to do this by removing the spray bars so you can blow any foreign material back into the spray bar. Then wash the spray bar out, making sure there is no foreign material inside the bars.
    Water will spray into the kitchen as you described, even though the bar or bars may not be turning.
    Please strictly follow our directions as varying away from our procedures may result in your not getting you appliance repaired, and your being unhappy with FixYa.
    Did you remove and check both spray bars, and, did you go ahead and wash them out to make sure there was not trash in them?
    Close the door with the spray bars removed, and turn the unit on momentarily, long enough for the pump to pump water through the system.
    Is, after you close the soap door, the door hard to open if you try to pull is open?
    Is the dishwasher an Asko, or what make of dishwasher is it? I cannot find the listed model number on Asko's website.
    1st, when you have used he dishwasher in the past, has the door been open when you go to unload the cleaned dishes?
    2) What is your indication that the soap is not rinsing clear off your dishes?
    3) What type of dishwashing soap are you using, and has there been any change since the last time the dishwasher worked correctly?
    We've had the same black scum build up in our dishwasher too, and I have yet been able to figure out what causes it. It's from the detergent, because that's the only common denominator between your's, mine, and other dishwashers I've worked with people on here at FixYa.
    What may have happened, is that removing and checking the spray bars, you loosened a spray bar that was not originally turning.
    Monitor the soap door over the next several cycles, and note whether it opens. If it doesn't, carefully check the spray bars to see if either are stuck. Also, make sure you have not loaded dishes such that the door cannot open (when the dish washer door is closed) and that water can spray against the door.
    Either one of these will tell us what to replace, particularly when we can duplicate the action, or lack there of.
    Let me know what you find out, and don't forget to rate me. And since this one is not easy to diagnose over the computer lines, if you would honor me with a FixYa, I would appreciate it. And I promise if you need any further help, I will respond to you (if I am not traveling).
  • Mark Egan Feb 03, 2009
    Thanks! And if you don't mind, bump me up to a FixYa. While we didn't identify an exact solution, I gave you what to look for, and will lay in waiting to help until it is up and running.
    I appreciate it, and thanks for using FIxYa.
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
The automatic detergent dispenser must be clogged. None is getting added to the cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 14, 2011 | GE Dishwashers
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher's detergent reservoir clogged
I have the same problem...I think I mixed the soap types (Enzyme based with Bleach based). The manual clearly says not to do this.
What I did was brought out my trusty wet-vac and sucked it out while using HOT water to break up the crusty mess. I am going to fill the dispenser with water and add soap the old way until I see the "low soap" light go on.
I'll keep you posted if this happens.
Oct 08, 2008 | Dishwashers
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Generic problem for all Vacuums
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Dishwashers Logo
434 people viewed this question
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
