recently I've had trouble while one touch record mode. The trouble is the unit freezes up, I cant 'stop', I cant 'eject' I need to get up & unplug the unit from the wall and reset it. This eliminates the recording to that point & the disc is ruined. anyone ever heard of this before and is there a solution ?
Comments:
Aug 03, 2007
- Thanks, could be heating issue, its above the cable box at the moment, the media I'm using is MAXELL, I picked up some new discs to see if I might have gotten a bad batch.
I have seen it as a heat issue and a firmware issue. Depnding on the age, Samsung might update the firmware to correct this problem. Can also occur with cheapo media.
On playing back a pre-recorded programme, this message keeps popping up for no apparent reason.it is...
(More)
On playing back a pre-recorded programme, this message keeps popping up for no apparent reason.it is most annoying, and sometimes I can`t get rid of it. Can you please help. The model is a Samsung dvd recorder No. SH853M Many Thanks. Tom
at times my dvd-ar650 DTV stops working. I have to unplug the power and do a hard reset(hold up and...
(More)
at times my dvd-ar650 DTV stops working. I have to unplug the power and do a hard reset(hold up and down channel when powering up). my current firmware is Reset Ok CPRM: OK, HDCP: OK CS: 01 FE: A25Z (M02) B/E Ver: 1.20070314.01.AR650/XAA FM Ver: 0.20070223.00AR650 CEC Ver: 2.20070215.32.AR650 ATSC Ver: 2007.0328 Macrovision : ST01
