Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Can't program the sleep button on the RCA remote
How do I program the sleep button on my Systemlink 8 A-V remote? I lost the manual.
  • Anonymous Mar 13, 2014
    rca systemlink 8 a-v
    President:
  • 814 Answers
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Posted on Jun 22, 2009
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
Aug 19, 2016 | RCA Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
I have lost the remote for the sharp dv-740. I have purchased a systemlink 3 RCA universal remote. I have tried all the codes for sharp and it doesn't work. Please assist me with this issue.
Codes normally using for Sharp
001, 002, 017, 029,094, 095, 096
Here is a link which will help you to program the RCA remotes Manually,Automatically and testing codes for maximum functionality
http://voxrightnow.custhelp.com/app/answers/detail/a_id/11073/~/programming-the-rca-rcr311b-remote-control
Feb 17, 2011 | Televison & Video
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
Code to program my remote systemlink 3 rca to my jvc televsion
Im trying to program my remote to my orion televisison how do i do that?
Jan 06, 2009 | RCA RCU300WBL Remote Control
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Nov 19, 2008 | RCA 3-Device Universal Remote with...
My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
Nov 15, 2008 | RCA Universal Remote Control
RCA RCR3273
I have a SYSTEMLINK rca universal control & I lost my manual of code
Oct 10, 2008 | RCA Universal Remote Control
Programing codes
Ok just click HERE to download the User Manual with Codes if you have a problem locating the correct code please let me know what Brand/Model# device code you need and I will give it too you. Thank you for using FixYa
May 08, 2008 | RCA RCU-SAT1 Remote Control
Universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote.  It's http://www.thompsontv.com/rcarc.html.
Mar 08, 2008 | RCA Universal Remote Control
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
257 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
