Question about Dell Dimension 3000 PC Desktop
Replacing RAM in Dell Dimension 3000
I have 256 MB RAM now, would like to upgrade to 2GB. Before removing the current RAM, do I need to back up to a flashdrive so I don't lose the files I have?
  • dtn09 Feb 14, 2009
    my dell dim 3000 wont accept my 1GB RAM, i turn it on and i get a bleeping noise, then i insert my old 256MB and it works.....have you got any ideas...i have the correct RAM
    thanks
    President:
  • 1,179 Answers
Upgrading RAM will not affect your files. Just make sure you upgrade with compatible RAM & that you install it in pairs. So if you want 2 GB then you would want to be 2 x 1 GB RAM chips. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 02, 2009
  • Dell Master
  • 2,404 Answers
You won't have to, installing RAM into a computer has no effect on the hard drive.
  • 596 Answers
Not really, but there is nothing wrong with being safe. ("...anything that can go wrong, wil!") Make sure you get the correct type of memory for your pc. Good luck.
  • Dell Master
  • 19,396 Answers
Upgrading RAM does not affect the content of hard disk, therefore your files do not get damaged.
However it is safer to make a backup of your files whenever you service your computer, like in this case.
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I have a Dell 8250 Dimension desktop. What would I need to buy to increase my memory?
I'l be flat out honest here, it is not economically practicable to upgrade the RAM in that system due to the use of RAMBUS RAM.
RAMBUS Modules in any significant size can cost more than a replacement computer that is currently available. There is also the MAX RAM limitation of 2GB for the motherboard.
Best Deal I could find is 2GB (4 x 512s) for $200
You could buy a new Inspiron 570 that will run circles around the 8250 for $300
http://www.dell.com/content/topics/segtopic.aspx/desktop-inspiron-570?c=us&cs=19&l=en&s=dhs&redirect=1
Jun 23, 2010 | Dell Computers & Internet
I added 2 mb memory to my 2 mb dell dimension c521 but it only shows 3.25 mb memory on my desktop when it should be 4.00
This is normal. You need a 64bit Windows if you want to see a bit more. The graphics can take up quite a bit of memory space.
Jan 03, 2010 | Dell Dimension C521 PC Desktop
Maximum RAM I can use in Dell Dimension 8500c desktop
please check our model number. here's link direct to dell memory locator page.
Nov 29, 2009 | Acer TravelMate 529ATX Notebook
I have a dell dimension 3000 and i want to upgrade ram
Best thing to do is to go to www.crucial.com and run their system scan. It will tell you how much you have, how much it will hold, and what kind of RAM you need.
Thanks for using Fixya.
Oct 14, 2009 | Dell Dimension 3000 PC Desktop
RAM for Dell Dimension 4600
Heres a link from DELL,it has all the correct parts and manuals for you,
This section is titled Removing and Installing Parts by DELL.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/parts.htm
Your memory is DDR Ram.
Aug 16, 2009 | Dell 1.44 MB Internal Floppy Drive for...
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Will it work
ya it works definetely.
Jan 29, 2009 | ATI RADEON X1650 Graphic Card
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Which RAM to use for Soltek SL-75DRV/-v
Leif: The difference in the numbers (2700 versus 3200) is speed rating-- basically, the higher the number the faster the RAM. Your computer is currently using 2700, so it's safe to use 3200, it's just faster than is currently used/specified.
Your computer is a Socket A - AMD Via-based board, so it is likely the motherboard will accept 1 GB memory modules. With three slots open, you would want to buy 2, 1-GB modules for best results. At current pricing, that would cost about $100. 2- 512MB modules would be next-best and around $55. Be sure to place the two modules in the slots next to each other, and closest to the processor for best results.
Nov 22, 2007 | Dell Dimension 3100 PC Desktop
Dell Dimension 3000 PC Desktop Logo
307 people viewed this question
Alun Cox
