Question about Kenwood KAC-848 Car Audio Amplifier
My sons kac 848 amp just stopped working
The power light is out. 12v ia available at the terminals both fuses are fine
    President:
  • 1,990 Answers
There is an Internal Fuse on Most of these Models that will blow from time to time. You might also check the Ground Connection. A loose Ground can cause the Same Problem. Please Rate My Response! Thanks!
Posted on Feb 02, 2009
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood amp worked fine yesterday when I went to start my jeep I noticed my sub was not working when I looked at the amp the blue light was not on, I looked at all the fuses they looked fine cant figure...
If the light is out, it's not getting power or is in protect mode to prevent further damage. If you have a voltmeter, measure the voltage between GND and 12V (BAT terminal) and also between GND and REM terminal (with the car and radio on).
If neither has voltage, your ground wire has come loose. If the bat terminal has no voltage, your fuse under the hood is blown (they can blow and still look fine sometimes) or your power wire is loose or broken. If the REM terminal has no power, your wire is broke or has come loose from the back of the stereo.
Jul 03, 2011 | Kenwood KAC8105D Car Amp
My son accidentally the pos and neg speaker wires together and the fuses blew on the amp and now the power light wont come on at all do you think the amp is damaged?
If I had to guess by touching the positive and the negative terminals together it probably fried up the transistors. While back I did the same to my amp and poof amp no longer worked. Took the amp apart to find the transistors fried up. Ordered them from the manufacturer but never installed them, ended up buying a new amp. Mainly, replacing the amp doesn't mean it would fix the problem....
Feb 22, 2011 | Kenwood KAC-9102D Car Audio Amplifier
No power to the amp i touched the power wire to the side of the amp
It probably burned a trace on the circuit board.
With the amp hooked up normally and the head unit on (so the amp will have remote voltage), do you read 12v DC anywhere on the case of the amp (black meter probe on the ground terminal of the amp)?
If there is no voltage on the case, confirm that you have 12v on the B+ and remote terminals of the amp (black probe on ground terminal of the amp).
Aug 25, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-7202 wont turn on
I have found the problem to my Kenwood KAC-7202. The amps fan was the only thing that would come on thats it. So I started checkin zener diodes cause all transistors checked out fine. So I remember readinf about a guy that had same problem and took it to a shop and they said it was some diodes. Well, thats what I was thinkin or the transformer. It turned out that 1 zener diode was no good, diode D9 1ss133. I took a zener out of an old vcr I use for parts and put it in and the fan came on as usual then the red light. Then I hooked my mp3 player to the rca input and hooked up some speakers and it works great. Hope this helps you other guys with the same problem. Check your zener diodes with a digital volt meter, if you get any measurement other than the reverse impedance which will read between 600 and 1200 ohms some lower or higher and then reverse the leads on your meter and if you get any reading it's no good and the reading will be 0-50 cause mine read 047 ohms.
Feb 09, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-848
You have blown outputs , faulty channels. What kind of amp do u have and what were u running to it? Most likely a bad amp, u might need a new one.
Jan 24, 2008 | Kenwood KAC-848 Car Audio Amplifier
Kenwood KAC-848 amp not working
It sounds like the amplifier is going into protection mode. This is generally due to shorted output transistors but can also be caused by shorted wiring. Disconnect all of the speaker wires and signal cables from the amp. If it still does the same thing, confirm that you have adequate voltage across the B+ and ground terminals (at least 11 volts DC). If the votlage acrosss the terminals is OK and the light still flashes with no speakers connected to it, the amplifier is in need of repair.
Oct 11, 2007 | Kenwood KAC-848 Car Audio Amplifier
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
