Question about Logitech EX100 967499-0403 Keyboard
Unable tio get the EX 100 Keyboard to connect.
The mouse connects ok, but I am unable to get the Keyboard to connect. In both cases using the same procedure.
Batteries are right up
  • bear57821 Feb 02, 2009
    I am using a USB port for the mouse and keyboard(as per your instructions)
    What do you mean" another keyboard bar code??
    I think you are asking if I am using proper sequence to connect? If so I am using exactly the same sequence that I used with the mouse, again as per instructions.
    No I can not test in another computor.
    The keyboard is an EX 100.
    Thanks
I've experienced the exact same problem :
mouse working ok, but i was unable to get any response from the keyboard.
i tried to update the drivers, i tried reinstalling the drivers on a clean boot, nothing would do. but then i tried to use my computer with a classic usb keyboard, which caused xp to detect both keyboards on startup, without managing to install either of them.
so that's how i found out my problem, which i hope is also yours, was that the proper driver for usb keyboards is not signed. so somehow xp would refuse to use it. forcing a manual install of that unsigned driver on both keyboards made the both of them finally work.
so if you have not tried that yet, i suggest you to reinstall your keyboard driver
without letting windows select the driver automatically (forgive any clumsy translation, i'm running a french version) :
1. find your keyboard in the device list (configuration panel > system > hardware > device list)
2. right click on it, go to properties, and choose reinstall driver
3. the installation wizard is then launched, tell him you wish to specify the location of your driver
4. in the second step of the wizard, tell him not to search for the driver, you'll select it manually from the list
5. in the list that appears next, select Human Interface Devices (my driver was in the HID section)
6. among the drivers in that section (there were 2 in mine), one of them is not signed, select that one and install it.
that's how i got my keyboard to work, hope this may be helpful to you in any way
Posted on Apr 30, 2009
  • jdwood18 Dec 18, 2010
    for some reason, only signed drivers show up... help please?
  • dario shinai Dec 19, 2010
    i've checked my drivers list again, some are signed and some are not. no matter what i do, i always see both signed and unsigned ones. the only question that comes to me is pretty silly but let's go anyways : did you install your mouse and keyboard drivers before going through the steps i've described oh so long ago ?
What conection are you using? for mouse and kyb.
Remember that when must use or both ps2 or just usb.
Are you usiny another keyboard, barcode,...?
Are you using the corect secuence to sincronice? (see under kyb)
Can you test in other computer or whith other EX110?
Posted on Feb 02, 2009
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
Not able to connect the keyboard
make sure that the mouse has fresh batteries then press the connect button on the receiver first then the connect button on the mouse, best of luck!
Jan 22, 2011 | Logitech Cordless EX 100 Mouse
I have a logitech desktop EX 100 and i cannot get the mouse or the keyboard to connect. do not have papers that came with it. i got the mouse connected a couple of times but when i tried to connect the...
Remove the software. Reboot. Reinstall software "drivers" Then plug the receiver in. Push the connect button on the receiver, then the keyboard, then the mouse in that order. Hopefully that helps.
Jan 21, 2010 | Logitech Cordless Desktop MX3200...
Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
May 28, 2009 | Sony VAIO VGP-WKB1 Keyboard
Logitech ex 100 mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 22, 2009 | Logitech Cordless EX 100 Mouse
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech ex110 keyboard stopped working all of a sudden. unable to connect. the mouse still works fine. checked the batteries, they are ok. I have a Cordless Desktop LX 300 mouse and keyboard set. My...
If you know the batteries are good, then turn the keyboard over and find the small reset/connect button and press it. This resets /connects the board to the receiver. If it still doesn work, press the button on the receiver and then the mouse. Hope this is of help to you. Bud
Aug 11, 2008 | Logitech Inc Cordless Desktop LX 300...
Logitech EX100 967499-0403 Keyboard Logo
1,309 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
