Question about HP Deskjet D4260 Printer
Printer will not work.
When I try to print will not print. Paper was jammed in at one time thne stopped printing after that. My lights on the printer are blinking.
    Champion:
  • 203 Answers
The paper is bloked in the printer take o look on the printer inside and see were is blokt.
Posted on Feb 05, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Suddenly HPJ4580 has stopped printing - when pressing print the first sheet sails through the printer and out the back with no print and the second sheet jams - no matter what I do - changed paper - turned...
I have problems with paper jams all of the time and it won't print once it jams. I turned off the printer, unplugged it, plugged it back in and turned the printer back on and it worked. You could try that.
Jul 17, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer repeatedly jams.
there would be little bits of paper jamed inside the printer, now wnen ever you tries to take a new print at that time the bits of paper blocks to come out..........just open the printer and clear off the papers
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Problem with printing an envelope
Not an ideal solution, but, Dell printers were not desined with envelopes in mind. (I used to work there)
My solution, if you value your time at all, pick up an HP personal laser printer. Costs a little more, but the time saved will much outweigh the inital cost.
You CAN get the dell printer to work a few times maybe but consistently is not a possility....
Feb 26, 2009 | Dell 1710n Laser Printer
Both power light and paper jam light on
clear the paper jam. take out the paper(if any) from back of the printer. Clear all prints in que and try to print
Aug 13, 2008 | HP DeskJet 970cxi InkJet Printer
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
HP Deskjet D4260 Printer Logo
135 people viewed this question
Ben Johnson
