Question about GE 25942GE2 Cordless Phone System
The base "charge/in use" light is blinking two blinks each time.
The msg counter shows "0". But the handset shows "New Voice Mail". When I try to play it, the phone says, "no new msgs.
Called comcast (phone service provider) and requested that voicemail isn't activated until phone has rung 7 times. My answering machine is set for 5 rings.
Posted on Feb 06, 2009
New CS6124 cordless. Charging now. Why does a red 0 flash constantly in base screen? How do you turn it off? Should it be always flashing?
The message counter will blink until the first time you
press "Play" ( yes, even when there is nothing ( 0 ) to
listen to ).
Actually, this blinking serves the real function of alerting
you to the fact that power was off/interrupted and now
the clock (Time and Day) will need to be reset.
Oct 01, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
My phones are Uniden DECT 6.0 (digital answering system). Why does a little red light in the upper left corner of each handset keep blinking each 2 seconds?
If it doesn't, you can reset it: With the phone in standby, open the
menu and select Global Setup; select VMWI Reset, then select Yes.
Jan 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
Base keeps blinking, and phone says new voice mail, read manual, says nothing about voice mail.Model 25942 series 5.8 Ghz Cordless Handset Answering system guide.
try unplugging the base to reset it. That voicemail signal is set on or off by your phone service provider. Check with them to see if a: you have v-mail or b: they can reset it
Sep 13, 2009 | Uniden Cordless Phone
My handset displays "New Voice Mail" and the base displays 00.
This is the problem, thebase charge light flashes continuously,It says that I have a new voise mail and the the base says (00)
Mar 04, 2009 | Uniden Cordless Phone
Answering switched to handsets
is the phone totally/fully charged
Nov 26, 2008 | Lands Phones
Voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
GE 25942GE2 Cordless Phone System Logo
224 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
