Question about HP Pavilion a620n (PC028A) PC Desktop
Computer turns on but i have no image on monitor
Monitor is blank coul it be my video card?
  • jerry_zavala Feb 02, 2009
    yes monitor workd\s
  • Brian May 11, 2010
    are you able to check the monitor on another pc? video card failure is a very real possibility.
  • 596 Answers
If your monitor is working, try taking all add-on cards out of your system to see if your monitor comes on. (Sound cards, modem, Network cards, etc.) If after doing this you still get no picture, very strong possibility your video card (on-board) is bad.
Posted on Feb 02, 2009
I have a IBM L151 LCD monitor which is 2 years old. recently while starting all of a sudden the monitor started displaying images in green color only. Secondly the horizontal images get restricted to half...
-try the monitor on another computer and see if it will be having the same problem
-if same problem w/ a different computer it need repair
-if not the computer that you are using w/ this monitor has a problem w/ the video card --try reinstalling the video card driver
Feb 25, 2011 | IBM ThinkVision L151 15" LCD Monitor
Well my compter screen is just blank when I turn it on first it won't do any thing so what do I do
If the LCD monitor has a faint Windows image, then the LCD monitor has a back-light problem and it could have a faulty inverter board or a faulty CCFL lamp.
Parts and service are available from LCD Parts, their WEB site is :-
Jun 28, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor comes on for 2 seconds then goes blank
Check if the cable connecting your monitor from the video card is properly secure and not loose...
You can also try this... turn off your cpu..remove the cable from your video card.....Open the housing....remove your video card from your motherboard... clean the contact surface of the video card with moisten cloth.... after cleaning...connect the video card to the motherboard...attached the cable to your video card.. close the housing and try to boot again...
I hope that work.. if not my suggestion is you try your video card in other computer, try also the monitor to other computer.. to see which one failed.
Much appreciated if you rate this help.. thanks..
May 23, 2010 | Samsung SyncMaster 920NW Monitor
Monitor turns on, show the logo acer and then goes blank.
Phill-B, I am having similar problems. When I switch to a different monitor, it works - so it is not the video card. The image is visible for just a few (2-3) seconds. It is saying that it is doing some sort of auto adjustment and, then, it blanks out. I think I can almost see an image when blanked out...but I am not fully certain. Any other solutions?
Apr 07, 2010 | Acer AL1716 17" LCD Monitor
Modrl 710N Monitor. I have just turned on this replacement monitor for the first time in about 3-months. The screen is blank with a flashing green light on the control panel. Pressing the test button tells...
When a monitor goes black and the solid green starts flashing it normally means the computer is sleep mode the screen saver blanked out the display the comp is off ect... However in this case since i assume you allready tried wiggling the mouse tapping the spacebar pressing the resume button ect... It is one of 2 things either the video card is going bad.( perhaps the computer has been on for a while and it is getting hot. With video card issues except the obvious, the case fan should be checked. there is a fan on the videocard it should checked as well the pc coul and mostlikely needs the dust blown out of it cause thats what kills fans and power supplies Hey power supply is the next possibility to th issue. No matter which part solves the problem I reccommend you do the other maybe premaintenance things I suggested. Good Luck.
Dec 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Picture ok for a few minutes then go blank
It's not the monitor it's your video card replace it
May 20, 2009 | Dell E176FP 17" LCD Monitor
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Monitor went blank
Let's try to isolate the problem:
-If possible try both monitors on a different computer.
-does the computer makes any sound when you turn it on?... do you get any image at all when you turn it on?
Jun 28, 2008 | Gateway 310S (2900621) PC Desktop
No Video
Did you take the monitor out and put it back in before the pin was bent? Or did it just all of a sudden blank out.
Jun 24, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
HP Pavilion a620n (PC028A) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
