Question about Health & Beauty
Trimmer does not cut
We used the trimmer once only and now we try to use it again and it does not cut anymore. We tried to clean it with a brush but it does not change anything.
  • spifer2005 May 11, 2010
    Are your blades moving back and forth at all? it may just need oiled if they are not.
    Problem Solver:
  • 12 Answers
Have you oiled it?
Posted on Aug 11, 2009
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
Hi I have a Wahl Super Trimmer model 1591/1592 1.2V. Have had it 3 months, It doesn't cut hair anymore and appears blunt! But yet it still easily cuts paper etc. I also can get inside it as it has been...
What are you doing trying it on paper! Never cut anything other than human hair with them or they ill go dull. Keep them clean with a small brush you brush out all the hair and use clipper oil after every use. If they have been dropped * even just a little bit " it sets them off and they wont cut. Go to a salon ask them who sharpens there tools and get there info and have them sharpened you dont need another clipper. and oil after every use with clipper oil no other kind!
Nov 22, 2010 | Health & Beauty
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
I have a Remington Clipper HC 10 that won't cut
TRY CLEANING THE HAIR OUT. USE A LITTLE BRUSH OR A TOOTH BRUSH TO GET IT ALL OUT
Apr 05, 2009 | Andis 01690 Hair Trimmer
Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Dec 25, 2006 | Braun Cruzer 3 Electric Shaver
Health & Beauty Logo
71 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
