Question about Uniden BC350C Base Scanner
Help how do i program the bc350c thanks
    President:
  • 2,761 Answers
Here's a link to the manual for your scanner. It will walk you through the programming process.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies and systems in your area, visit
www.RadioReference.com
or
www.CityFreq.com
Posted on Dec 06, 2009
How do i program my 350a scanner
Your BC350C is a factory pre-programmed scanner, and you cannot program is in the standard manner (e.g., directly entering a frequency via the keyboard). You can, however, transfer any displayed frequency from the SCAN or SEARCH mode into your PRIVATE bank. Clear instructions for doing this are in the factory manual that you can download and print, at no cost, here:
Bill B.
Listening in since the 60's
Jan 23, 2011 | Uniden BC350C Base Scanner
Do not know how to progam need help
The BC350C is a pre-programmed scanner, and you cannot program it in the conventional manner (entering a frequency via the keyboard). You can, however, transfer a displayed frequency from SCAN or SEARCH mode into the "Private Bank." Detailed instructions for doing this are in the factory manual that you can download and print, at no cost, here:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
Dec 29, 2010 | Uniden BC350C Base Scanner
How do you manually program known frequencies in a Uniden BC350C scanner? There are no numerals to key in.
Sorry, but your BC350C is an oddball that does not allow manual programming. You have to lock on to a freq in the SCAN or SEARCH mode, and then move it to the PRIVATE bank. Details are in the operating manual which you can download and print, at no cost, here:
Bill B
Aug 24, 2010 | Uniden BC350C Base Scanner
How to program it
Oddly, the BC350C does not have a direct-entry (keyboard) programming function. Frequencies can only be entered into the "PRIVATE" bank by transferring them from the SCAN or SEARCH functions. This sounds confusing, but the programming steps are detailed in the scanner operating manual, which you can download/print here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 05, 2010 | Uniden BC350C Base Scanner
How do you program the bc350c scanner
Conventional frequency programming is fairly simple, but programming trunk systems is more detailed and can't be adequately covered in this forum. Please follow the link below - it will allow you to download/print the manual for your 350c, and the manual will walk you through the programming steps.
For a comprehensive database of active frequencies and trunk systems in your area, visit
I hope this helps, but if you have any more questions, please contact us again.
Dec 09, 2009 | Uniden BC350C Base Scanner
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
How do i clear all channels and start over putting in new ones
There is no global clear/erase function on the BC350C, but programming a new frequency on a channel automatically deletes/erases the old frequency. To delete an inactive or troublesome frequency, program "000.0" in that channel. Doing so will deleted the previously programmed frequency and set the LOCKOUT to ON for that channel. For more information on deleting frequencies, see page 27 of your operating manual.
Need the manual? You can download it here:
Sep 13, 2009 | Uniden BC350C Base Scanner
How do you program?
I couldn't find the "A" but here's a link to the manual for the BC350C. Hopefully it will help.
http://uniden.com/pdf/BC350Com.pdf
Aug 05, 2009 | Uniden BC350C Base Scanner
Program
Here is a link to the operating manual for your scanner. It will walk you through the programming process.
or
www.CityFreq.com
Jan 14, 2009 | Uniden BC350C Base Scanner
Programming a Scanner
Hey Emkat, here is a link to your owners manual, all you have to do is download it and print it. The programming starts on pg 24.
If you need freq's to put in it, go here;
http://www.radioreference.com/apps/db/
Just click on your country, state, county and it'll list all the freq's for you. I hope this helps you out in your search, let us know; Mechanic
Feb 12, 2008 | Uniden BC350C Base Scanner
Uniden BC350C Base Scanner Logo
75 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
