Question about Nostalgia Electrics CCP-509 Popcorn Maker
RETRO POPCORN MACHINE
FRON DOOR BROKE WHEN KERNEL POPPED OUT WHERE DO I GET A NEW DOOR. JUST GOT THIS FOR CHRISTMAS..
  • jaken35 Apr 15, 2009
    I E-MAILED THE COMPANY AND NO REPLY....STILL WAITING AFTER 2 WEEKS
  • 520 Answers
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
Oct 24, 2013 | Nostalgia Electrics CCP399 Vintage...
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
Mar 09, 2011 | Nostalgia Electrics KPM-508 Popcorn Maker
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
Kernels jump up and out of maker while maker is working. At least 50% of kernels are wasted. Thanks for your help.
This won't totally solve the problem, but do the following:
  1. turn on the machine and allow to run for about a minute to allow the machine to get hot.
  2. add 1/2 again as much kernals to the popper
  3. tilt the machine back slightly while popping begins
this should reduce your wasted kernals!
Mar 15, 2010 | Toastess Hot-Air Corn Popper Popcorn Maker
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Popcorn jamming in kettle
The only real solution is to put less kernels in kettle - it pops so fast that it jams up and burns. Adding a little more oil usually helps as well.
Dec 12, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Nov 06, 2008 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Kitchen Appliances - Others Logo
173 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Archaeology
Archaeology
Richard Roth
Richard Roth
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
