Question about Manhattan (168670) Computer Speakers
Broken volume and tone remote cord for the SoundSource 3200 Seies
I have a Manhattan 3200 SoundSource Series with 2 computer speakers and a bass woofer. It's a great system. Now the connector on the volume control cord won't go back into the bass woofer female connector. It may be the pins are bent.
Do you sell that remote volume cord with the volume and tone controls on one end and the pin connector on the other?
Thank you.
I just need a new connector cord as described. I was hoping I could buy a new one.
But it looks like I will have to take it to an electrical fix it shop somewhere to see if they can fix the pin connector.
Thank you.
Posted on Feb 03, 2009
Wiring change from Fender
Standard J-Bass wiring is parallel. Not series.
To run the pickups in series, the ground of one pickup would feed into the hot of the next. That's not what comes from the factory.
Mar 15, 2016 | Fender Music
Where can I find a satellite speaker that controls the sound?
For the most part volume is controlled on computer, though speakers may have separate volume \ bass \ treble controls. Or, are you looking to purchase?
Aug 31, 2012 | Harman Kardon SoundSticks II Computer...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
I cant adjust bass
You proberly have to download some drivers or them mate, google it :)
please rate
Feb 21, 2009 | HP JBL Platinum Computer Speakers
Bass tone problem
Both of your problem amps were made in the '70's or earlier. It is entirely possible that the coupling capacitors are failing. This is an issue for a service center whether it is caps or something else, like failing tubes.
The good news is that installing metalized polypropelene capacitors will make those classic amps sound incredible.
Nov 04, 2008 | 3Com SuperStack II advanced RPS...
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Sound not coming out of speakers
just remove the cord from CPu...the sound cord and re-plug it and try the option line out or line in...
otherwise simple way is that...check wheter there is sound installed in Control panel under the add or remove program tab....
if not,then install the driver from *********** Board CD..
simple restart the PC it is required..
and for more queries post it on..
under the guest book..
i will sort it out as soon as possible..
Dec 04, 2007 | Manhattan 1100 Computer Speakers
Manhattan (168670) Computer Speakers Logo
150 people viewed this question
Top Manhattan Audio Players & Recorders Experts
Are you a Manhattan Audio Player and Recorder Expert? Answer questions, earn points and help others
