Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Tig my pudle melts into gray not shinny - Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
  • Robert Lee May 11, 2010
    Hi
    are you welding alloy, are you using AC current, what gas?
  • 92 Answers
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Posted on Feb 15, 2009
Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
Oct 08, 2011 | Miller Electric Manufacturing Electric...
Finding it hard to get the metal to pool
Simply turn up the amperage on the welder. The thicker the material, more amps are need to heat the parent metal.
However each metal is different and other factors come involved. For example, Aliumium melts at a temperature of 660 'C but has an oxide layer on the surface which melts at roughly 2100 'C. Therefore you need a T.I.G. welder with a polarity of AC HF (high frequency), to increase the hertz to deal with this high melting temperature oxide layer.
There are other factors such as sharpening the tungsten to a point if welding stainless steel/carbon steel. By doing this the arc is applyed in one direct spot rather then disposing so you can heat the metal into a pool quicker.
Make sure you have your polarity right:
DC Negative = more heat into workpiece, deeper penetration. Standard setting for steel
DC Positive = more heat into electrode, less penetration, best left for thin metal.
AC, best for non-ferrous metals, like aluminum, because the back and forth flow provides cleaning action.
Apr 16, 2011 | Welding Tools
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My tungsten appers to be melting when i am welding aluminum also leaves black residue when welding
TIG TORCH MAY NOT BE RATED AT THAT AMPERAGE .MIGHT BE BETTER TO USE 1/8 PURE TUNGSTEN. BLACK RESIDUE MAY BE CAUSED THE CORROSION OF COPPER GUTZ DURING WELING ,DO TO INTENSE HEAT. OR MAYBE CAUSED BY FAILURE TO CLEAN METAL AND/OR DIPPING THE TUNGSTEN.
Jul 02, 2009 | Miller Syncrowave 200 Tig Welder Cover...
I get an pudle of antifreez in morning under car
Sounds like the water pump is going bad.
Mar 16, 2009 | 1998 Buick LeSabre
TIG MIG Difference
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Radnor A35HP 350A Water Cooled 25' TIG...
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
243 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
