Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Aficio MP161 Coin Op
How do I get into the sp mode and set this copier up for the coin op.
    Genius:
  • 2,120 Answers
Press USER TOOLS
Posted on Feb 02, 2009
I have A cocktail Mrs Pacman Was Working Perfect Then One Day I turned It on And It Comes Up with Lots Of Numbers And Letters Then It Will eventualy Come To the Mrs Pacman Screen As Soon As i Start To play...
Your coin op video game most likely has electronics that are deteriorating due to age and dust. It's actually a pretty common occurrence with older coin op machines. Components like capacitors degrade over time and eventually the electrolyte leaks out, contaminates the PCB, and the analog and power support circuits fail. The dust that builds up on the PCBs absorbs moisture from the air over time and can eventually bridge electrical contacts causing shorts that can lead to all kinds of problems.
Your best option IMO is to simply look for a local arcade and coin op machine repair service. The Internet should be a good place to start. If you are still having difficulty finding someone to repair it, simply ask around at any arcade or other location near you that has coin op machines and they should be able to point you to people who repair them.
Oct 10, 2017 | Namco Ms. Pacman Galaga Cocktail Video...
Reset to Default/Factory setting
Get into the SP mode and do an SP5-801, that should blow everything out. Later models had an SP code that allowed you to get rid of the Key-Op lock out code, but I don't think the A232 had that capability.
Oct 09, 2009 | Ricoh Aficio 450 Copier
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Disable coin vendor
It is easy to do... Just take the cover's off that will expose where the coin op wire is pluged into the copier. It is a 4 wire clip, I believe. Turn the copier Off and cut the wire on the coin op side and strip the wires. Of the wire's that are there you only need to have two of the wires jumed togather.to make the copier to work. I don't know how many wires are there they may have 2 or 6 or 10, it depends who made it. If you are lucky they may have left the jumper clip in the copier, just connect it again. If not jump two wires and turn copier ON and see it the display is un-locked. If not try another set. It is trial and error. You should be able to fix it. Good Luck
Jan 30, 2009 | Minolta EP4000/5000 CS/PRO Copier
Conecting it to a coin machine cartadis cm4000
Enter SP mode and select SP5113 - Optional counter type.
Good luck and please rate me, thanks.
Nov 11, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Aug 28, 2008 | Whirlpool Dryers
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
324 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
