Question about Jenn-Air JCD2389G Side by Side Refrigerator
Hot Frame When either door is open, the frame column that seperates the refrigerator from the freezer is very hot to the touch. Normal or problem?
  • karen_moschi Feb 02, 2009
    Will do and advise success. THANKS
  • 410 Answers
The hot frame is due to poor or no air flow across teh condenser coil located in the compressor compartment in the rear of the unit. pull unit from wall remove card board cover and there is a fan that should be blowing. while you have it pulled apart be sure to clean the coil. the jelly roll looking peice the motor is mounted to. if the motor is bad you can put a house fan blowing on it until you get a ne fan installed. thx peyton
Posted on Feb 02, 2009
  • peyton thompson
    peyton thompson Feb 02, 2009
    glad we got you fixed up if everything is ok a rate of fix ya would be great. thx peyton
Hot freezer frame
the freezer frame is hot because it is used to disipate the heat from the coil and keeps the door frame from condensations at the door gasket.
Dec 24, 2014 | Refrigerators
Why is the door frame so hot?
the door frame also acts as the condenser for the fridge hence the heat
Sep 11, 2014 | Refrigerators
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Exterior of refrigerator between freezer and refrigerator is hot to the touch
It is normal unless there is a lot of dust below your refrigerator blocking airflow. What you feel is hot gas tubes behind the surface of the metal to help reduce moisture around the door frame and door seals that will get hotter should the fan and condenser below refrigerator have a blockage of dust blocking airflow, Sea Breeze.
Jun 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Freezer door frame is extremely hot
The frame should be warm but not excessively hot. This is called an anti sweat heater. It's purpose is simply to keep the door from sweating under normal operation. It sounds as though this heater is going out. You may want to have it replaced very soon. Once it completely fails the freezer door will start to sweat and cause water to pool on your floor. Hope this helps, good luck!
Nov 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
The external metal frame is VERY HOT
Your condenser fan is probably not running. 99 percent of the time that you feel that hot spot it is from the condenser fan not running and the unit is not rejecting any heat
Sep 13, 2009 | Refrigerators
Side by side getting very hot on top left side of freezer and between the doors where the door liner touches the frame
Not quite sure about top left side, probably normal.
But the hot door liner is definetly normal, this is so the liner remains plyable and doesn't freeze to the frame.
Fuji
Aug 06, 2009 | Refrigerators
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
148 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
