Question about Refrigerators
Westinghouse upright fridge model no: RP432v-L
The reservoir seems to be overflowing out onto the floor, but cant figure how to get to it to unblock or empty?
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
Posted on May 31, 2009
  • 67 Answers
SOURCE: ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Posted on Aug 11, 2009
arikrom
  • 528 Answers
SOURCE: Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Posted on Jan 03, 2010
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
Water leak fridge
The condensation in a fridge is generally routed to a small drain hole at the bottom at the back. The water drained off here normally drips onto the compressor unit (the big black ball thing at the back) where it gets evaporated off, due to the heat the compressor generates. Before taking steps to unblock the drain, you might consider defrosting the fridge first. When unblocking the drain, do not use wire, unless the fridge is switched off and unplugged, you never know where that wire will end up (electrocution risk!). There are two good ideas for clearing the blockage. The best way off clearing the tube is with compressed air, often difficult to get in your kitchen, but don't despair, there could be two solutions in your garden shed. If you have a Weed-killer Spray that uses a pump to pressurise the spray pot, you could use that to clear the blockage (with a bit of ingenuity). Clean the spray thoroughly first, you don't want to poison anything in the fridge, and use the spray with no liquid in it. You can take off the spray nozzle and use the pipe in the hole. If you need to manually unblock the tube, you could use a hard nylon "cord" that is used in a garden strimmer. Pocking that down the hole and into the pipe should do the trick. It's flexible enough to get around the corners in the pipe and when it emerges at the other end it won't electrocute you if it touches a live connection. Lastly, having removed the blockage, put a very tiny bit of "plughole unblocker" fluid in the pipe, that will clean out all the other residue not pushed out with the cord. Good Luck!
May 11, 2014 | Fisher and Paykel Active Smart E522B...
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
How do I empty the tray when full in the back of my model 253.74810400 fridg? Also leaking water from somewhere onto the floor.
the water on the floor will be from the overflowing reservoir at the back of the fridge. i would suggest buying a syringe ith at least 20ml capacity usually you can get them from hardwear shops, and use it to emty the tray at the back. Make sure that the pipe leading from the drainage port to the reservoir (drainage port is located inside inside of the fridge at the back) is sitting inside the collection reservoir and not hanging over the side causing the puddle.
Aug 08, 2009 | Kenmore Refrigerators
May 31, 2009 | Maytag MSD2656G Side by Side Refrigerator
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
for reallybsq
for guest.
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
