I have a Comfortmaster Heater Mod# GDE125J20A1 and can't seem to figure out where a filter goes on the unit. Any idea?
  • 4 more comments
  • aaronmaxkend Feb 03, 2009
    yes it is in an indoor closet
    Yes, that is exactly how it works.
    I have filters in the cold air returns. My question is should there be on in the unit also?
    Thanks, you are the BEST! I just wanted to verify before diving into the *&%^&*# top of the unit!
  • Ken Bledsoe May 11, 2010
    Does the return air come from the top? And the supply air go out the bottom?
    Is this unit inside a closet?
  • 306 Answers
Okay the filter on your unit is on top where the duct work connects to the air handler. Should have a panel in the front that will have to remove the flue pipe is right in the middle of it so will have to work around it. The filters are located across the top might be laying flat or at a small angle. On these type of units they are not very easy to change out.
Now in the event that the filters are not there look in the return grills in the ceiling might only have one they put the filters there also.
let me know how it goes. You will need something to stand on to access either place. ken
Posted on Feb 03, 2009
  • Ken Bledsoe Feb 03, 2009
    No that is the filters that the unit uses. you will be glad that they are in those returns as on the unit it self would be a pain in the _______tt to change out every 2 months or so.
Can't figure out how to turn on heater. Seems
does the air come out of the defrost ducts no matter what you set it on? if so you may have a vacuum hose that is off under the hood that goes into the fire wall
Jan 13, 2010 | 1994 Oldsmobile Ninety Eight
I have a Meyer mod # E-60H. Last year it seemed
You got the idea, because both the motor carbon
brushes and a weak battery is one of the major causes of your problem. So, have a check on these items.
Furthermore, also check the oil as well as the oil filter
if it needs to be replaced. When all the checks are done
and fixed, I'm sure that you will get the best result . Hope this will help you.
Oct 23, 2009 | Plumbing
It say E2 missed ignition,dont have owner manual to figure out what to do
Common causes for an EE2
-no fuel
--out of fuel
--tank too low
--valve closed
--air pocket (recently out of fuel)
--clogged fuel filter
--clogged fuel strainer (inside the unit)
-clogged flue
-malfunction of:
ignitor
circuit board
flame sensor
fuel pump
blower motor
(or otherwise cannot get fuel)
It's a common error that could be alot of things ensuring that the unit is recieving fuel is the first thing to check.
If the heater hasn't been serviced in the last year or 2, it wouldn't be a bad idea to have a service technician go through it.
-Helping Hands Services
Fairbanks, Alaska
Oct 08, 2009 | Rinnai Toyostove Direct Vent Heater:...
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
We have an LG SQ/SR/ST chassis inverter model air conditioner....the airconditioner keeps stopping with the screen display...C6 appearing. When we turn it off at the mains it seems to reboot it for a while...
i can figure out what model a/c you have from this discription/ is this a lg floor mod. or window model or lg duckless split system
one comon problem causing faut is dirty filter or condensor but hard to figure if i cant place the unit disciption.
Oct 20, 2008 | LG Heating & Cooling
Hoover nextra mega load 7.5kg HNC175 condenser dryer has 1)stopped heating, the drum still goes round and cold air goes in. 2) The filter care light is on, i have taken out the condenser assembly and...
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Apr 03, 2008 | Dryers
RC150F
http://www.desatech.com/manuals.cgi?oldpro=Construction+Heaters&products=Construction+Heaters&Manual=&Model=RC150F&Type=Show+All&x=75&y=11
Check out this link. There is a detailed owners manual and other info.
Feb 11, 2008 | Reddy R155D Utility Heater
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
