Question about Philips Magnavox 27MS343S 27" TV
Magnavox CT270MW8A 27in.TV/DVD/VCR blows fuses/won't power on/up
I was donated a Magnavox CT270MW8A 27in.TV/DVD/VCR of the mentioned type and model for a potential fix and keep. I would love to keep this set, as I don't have the ability, or time to get a new DTV or even a converter box with the deadline for conversions approaching FAST. The chassis is made by FUNAI, and they have NOTHING available in the way of a TECH service manual. However, I have had several computers, and limited experience with repairs of electronic, mainly amateur and at-home jobs, with a 100% success rate. Based on the symptoms (i.e. put in 3 new fuses as specified in the board, plug set in and it blows the fuse IMMEDIATELY, without even turning the set on. There were flashes on/at the poles of the plug itself and the fuse inside each time I plugged it in. I suspect the problem is in the power supply section of this unit (either at the transformer [it uses a flyback-type of t-former] the power relay, or the thermistor [whatever that is, please explain] ). I called an on-line store, the only one listing any parts for this unit, and these are the only one available, anywhere that closely might ZERO IN ON THE CULPRIT. Based upon this, or the process of deduction, I am willing to replace these parts, any or all of them myself, if they are 'plug and play' , AS IN A COMPUTER INTERNALS SWAP OUT. It appears to have a 'motherboard' as does a computer, so I see similarities in design and symptoms. My question IS: are these components merely R&Rm (unplug old and replug new), or do they require extensive soldering and therefore extensive testing???. HOW do I ID them on the board??? Do you or can you get a
SERVICE Manual??? If I replace them all, following all safety precautions and protocols OF COURSE, and the problem is still not solved. I will still take it in for service. I have solved these symptoms on two computers, but NEVER a TV set, particularly not a TV/DVD/VCR combo. I realize there are several basic tests for continuity using a MULTIMETER as a preliminary at certain junctures on the board, and power cord and GNDS. Can/would you help me please with options, alternatives, and no-way-outs? I am disabled on a fixed income and had a hard time getting it into my apartment with a bad spine/back and no help, but made it this far The.set is brand-spanking new (2007) with no visible use at all, and probably had a power surge knock out or short the board somewhere is all, and should not be junked. At $100(+) just to get it in the door of the nearest shop, not to mention logistics, your help would be priceless to me right about now Again, PLEASE&THANKS. RG
Why does the vcr eject the casset
Posted on Feb 19, 2011
Does The Magnavox Dvd Recorder / VCR zv427MG9 Have An In Line Fuse
There is a replacable glass cartridge type fuse inside it. It can be located at its mains power supply regulator board.
Jun 09, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
No Power
check fuse most likely power supply shot shop at yard sale or pawn shop for new tv!!! :)
Jul 07, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Phillps vcr/dvd player
I can't get the TV Stations to come through after we hooked it up the model number is DVP3345V/17
May 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Model Magnavox DV200MW8 DVD/VCR Combo
try www.videohelp.com then type in dvd hacks there are various sites to go through.you can use search engines to your advantage.
good day
kz
Feb 20, 2008 | Philips Magnavox 20MC4304 20 in....
Keeps blowing fuses
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox 27MS343S 27" TV Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
