Question about ASUS K8N-DL Motherboard
Turning off drive stripping and enabling IDE single mode
  • 4 Answers
I have replied to you previous post!
Posted on Feb 02, 2009
How do you make the ide drive primary in the poweredge 1400sc
Master can be single drive on one IDE channel. Or, one master and one slave on a single IDE channel. From there you have the option of expanding over to the secondary IDE channel. Hope this helps.
Feb 13, 2013 | Dell PowerEdge 1400...
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
New IDE Drive - will it work on my Desktop?
According to the manual for your computer it only has SATA connectors. 4 to be exact. There are no IDE connectors.
SATA cables look like this:
There are many good SATA drives out there. It is a better (faster) drive besides.
Mar 19, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
I am unable to turn on ide single drive
You need to turn the raid back on and go into the raid utility. Once in the raid utility u should see a function to Break or Delete the raid group. Do this and then the drive should revert to a non-member disk and therefore a single drive. Once this is done u can turn the raid off again.
Feb 02, 2009 | ASUS K8N-DL Motherboard
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Primary IDE interface fails to load
many new motherboard does not recognize slave mode on if single ide drive connect
verify both drive set is master or not after that you attach to primary your harddrive and secondary cdrom
your reset problem is wirering connection see your motherboard manual
Mar 03, 2008 | Jetway (V2MDMP) Motherboard
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
ASUS K8N-DL Motherboard Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
