Question about HP DeskJet 420 InkJet Printer
How do I clean the rubber belt
The printer makes a lot of noise every time I print and towards the end of the page only half the words are printed. it seems the rubber belt is causing the problem.
    Problem Solver:
  • 6 Answers
Its probably the metal shaft not the belt that is causing the problem. Sometimes it gets dirty because the bushing underneath the print carriage gets worn. You can clean it by applying light oil to a cloth and wiping the shaft.
The printing issue maybe caused by a timing/clutch problem. You can try turning the printer off/on with NO paper in the printer several times to try and reset it.
Posted on Feb 04, 2009
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
If I print a large quantity in one print, the first two or three pages wil print fine then the rest will mess up. The left hand side of the page will mis-print and it squeals every so often. I just...
the drive gear assy. that moves the opc belt are broken.
honestly is time to get a new machine instead of spending a lot of money trying to fix this Lemon,sorry.,
Sep 10, 2010 | Brother MFC-9420CN All-In-One Laser...
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
Prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Aug 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
Page two of a word document prints so every other line is faint
do 1 thing, save document-2 as a pdf file and try to print one document @ a time. it will resolve the issue.
Jul 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kyocera Mita FS-1000+ paper slip single page? 5 pages print ok
This is a known problem.
Kyocera pretends to produce very silent printers. Therefore certain sheet metal parts inside the printer have a small piece of sponge rubber at their endings.
Unfortunately over the years this sponge rubber gets sticky. The corresponding lever, that is covered at its end with sponge rubber, sticks too long to its initial position. This is the reason why a certain lever is moved too late by the electromagnet into the position where a certain pulley is released.
As a result printing and paper movement are no longer coordinated and the printout is too low on the sheet.
Solution: Get rid of the sponge rubber, clean the lever very well in order to avoid it from sticking in its initial position. As a result you will here a much harder metallic noise when the lever moves, but the printout should be o.k.
Apr 07, 2009 | Kyocera Mita FS 1000+N Laser Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Words Copied Multiple Times
Yes Cartridge problem is what causes double imaging 95 % of the time, there is a rubber blade in the drum unit that wears and doesn't clean off old image from drum. Have known this fault to be fuser at times, the way to tell is to get a print to stop half way threw machine by openning door during print, remove cartridge and look at print, you want it to be stop before the fuser(hot bit) but after the drum, image still rubs off if pre fuser and then you can see if defect is present before paper travels threw the fuser, but in your case I think you will find it is not the fuser it is toner cartridge.
Nov 24, 2007 | Office Equipment & Supplies
Out of order printing..
You did not adjust the label sensor.(media sensor)
1- for labels with a noth move towards the notch
2-for labels with a space between them move towards middle.
look at page 28 (zoom 400%)
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Oct 16, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
HP DeskJet 420 InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
