Moisture inside TV
I have a panisonic LCD TV... my son sprayed it with a mister (fine water mist) this morning. I wiped it up once I'd noticed, but I fear mositure is now inside the tv because there are some blackish streeks when I turn the TV on. I tried blowing it with the hair dryer and that seems to have helped a little bit, but not alot... is there anyway to fix this?! PLEASE
  • Anonymous Apr 10, 2009
    Boys! My son did the same thing and I took the same measures, but the same black streaks are there. Does anyone know how you solve this?
Sorry to say the info I was given here didn't prove as useful as I'd hoped. Thank you however to those who tried!!! I called a TV repair man and spoke to someone in person, this was much more useful.
Posted on Feb 03, 2009
Hi guys, I have got a spot on my Sony 40" LCD TV which i got when one of my cat urinated on the TV. its about 4 inch in diameter and is on the bottom right corner of the screen. Now my quest
moisture and electrics dont agree with one another. Could try
isolating from the mains and spraying lightly with car windscreen
de-icer (isopropanol) wipe off any excess and leave in a warm spot for
a few days....Might work if you are lucky
Oct 27, 2014 | Sony "BRAVIA EX 400 Series 40-Inch LCD TV,...
My son took a baby wipe to the LCD tv screen and now there is a purple streak I tried a damp soft cloth but that didn't work any suggestions how to clean the baby wipe off?
Try a 50/50 solution of water/rubbing alcohol and a micofiber cloth. DO NOT SPRAY THE SOLUTION ON THE SCREEN ITSELF but on the cloth then wipe down the screen. I hope the screen isn't damaged !!!
Sep 22, 2012 | Televison & Video
Replace distributor cap and coil
Ken ,you will have to replace the cap,but just for the heck of it,take the cap loose and if you have some silicone spray or w.d.40 spray the inside of the cap ,let it set for a few minutes ,wipe it out ,reinstall ,and redo a water test,with a water hose ,set the water nosel on mist ,do this while motor is running . it'll give you a little time until you get a chance to change it. and it will help you pin point the problem.
Jul 04, 2012 | 1992 Cadillac DeVille
Car stops while driving somtimes starts and goes no problem, somtimes needs to rest for a few min then it it starts and goes so I drive home.
I had the same problem once, it turns out I had moisture inside my distributor cap, when it dries out it runs fine. I had a hose that was spraying a little mist on the cap. Also check for a cracked cap or just replace it.
Oct 26, 2011 | 1993 Dodge Spirit
We have an in wall air conditioner. I am not sure of the model #, but recently it has started spraying a fine mist back into the room. I removed the front of the unit this morning and found that the foam...
You could have a pin hole in your refrigeration line. The mist is probably the refrigerant coming out. Check the coil very carefully to see signs af any breaks. You may also have a bad drainage and the water is accumilating inside the unit. The fan blades can throw the water against the filter. Look inside for standing water. Good luck!
Aug 04, 2011 | Fedders A3X05F2A Air Conditioner
I have a 94 s10 tbi it runs fine when its completely dry out but loses all power when it rains or snows what is my problem
it is a spark issue.
im pretty sure these have a coil pack ignition.
when a coil pack gets old it may develop a crack and anytime moisture gets in the coil it kills the spark and the engine doesnt burn fuel like it should.
the way to check for a cracked coil is to start the engine and get a spray bottle full of water and spray the coils with a light mist of water. the engine should die down or quit completely if a coil is cracked. you will notice no difference if the coils are fine and the water will not damage anything.
if you have a cracked coilpack then it will need to be replaced accordingly.
Feb 06, 2011 | 1994 Chevrolet S-10
Children sprayed water on 46" lcd TV, and it looks
Oh dear! I would check your household insurance if it was an accident, just in case a replacement is required.
Most items that get wet rarely recover without problems.
The water should not be able to get into the screen as it is a sealed. If the water has not entered the TV, you may get away with wiping the screen with an almost dry cloth that has dilute detergent on it, (washing up liquid and warm water is fine). That will remove the streaks.
Nov 08, 2010 | Hitachi Televison & Video
Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
May 29, 2009 | Sunbeam Steam Master 4055 Iron
My son sprayed our tv with a fine mist. I wiped it up once I noticed it, bit now hours later there's blackish grey streeks on the screen when I turn it on. I assume it's mosture inside the TV.. how can I...
Ok you have to unscrew the screws on the upper backpanal of the tv to access the inside of the screen(be carefull yhe mirror is connected to this panal!) one back is off wipe and c;ean inside of screen and wile its open you might as well clean the mirror and the lenses too! you will notice a better picture! now just screw panal back into place and your done! dont be scared its not hard to do at all! Now you better move it before you husband gets home!
Please rate my response!
thank you!
Feb 02, 2009 | Televison & Video
Water Damaged lcd tv?
Hi there.My 3yr old son water gun our 50" lcd tv sony bravia.I nearly have a heart attack.LOL.There were black mark at the bottom of the screen and when I touch it it's moving around.I realize that it was the water.So I didn't do anything.When we don't watch tv I turn it off from the wall.I kept doing this and after two weeks I notice that the black mark has gone.I don't why>So may be you could just leave as it is...good chance it may to away itself.I hope this helps.thanks.
Mar 23, 2008 | Televison & Video
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
