Question about Car Audio & Video
Odometer light on A 160
Light that illuminates the odometer stopped working.
Not the fuses.
Any ideas?
Thank you.
gw@tourismresorts.com
  • 486 Answers
IT WILL BE THE BULB, YOUNEED TO REMOVE DASH AND REPLACE, GET BULB FIRST AS CAR NOT DRIVABLE WHEN DASH IS OUT
Posted on Feb 02, 2009
1992 toyota 4runner sr5 speedometer stopped working and check engine light illuminates
If you have someone check the engine computer for trouble codes, you'll probably find a code for the speed sensor in the transmission.
Feb 10, 2014 | 1992 Toyota 4Runner
Speedometer and odometer not working
I would look at the ignition switch and the neutral safety switch for voltage. It could be the ignition switch is worn out and not making contact with all of the circuits. The neutral safety switch would be affected by moving the shifter.
Aug 05, 2012 | 1998 Chevrolet S-10 Pickup
Gauge cluster Illumination problems
Do you have the dash light dimmer control turned off by mistake, a common cause. It is next to the headlight switch.
Jul 25, 2012 | Cars & Trucks
Lights or fuse for my speed odemeter guage and heater/air conditioning system
These lights for the dash are controlled by a rheostat instrument control dimmer switch next to the main light switch for the headlights, it is either turned off (have seen this dozens of times) or it is defective. Below is a picture of the switch assembly I speak of. The thumb wheel next to the knob is the dimmer control.
Feb 13, 2012 | 2000 GMC Yukon XL
Dash lights do not work
Power is supplied to the instrument illumination by the "TAIL/ILLUM LIGHT" fuse, Fuse #4 (15 Amp) located in the dash fuse block under the left side of the dash. This fuse provides power for both the primary and secondary sides of the TAIL LIGHT relay. The Combination (Headlamp) switch provides a ground path for the primary circuit of the TAIL LIGHT relay. When the primary circuit is completed by the Combination switch, the secondary contacts close and provide power to the tail lamps as well as to all of the instrument illumination bulbs. The ground for the instrument illumination bulbs is a variable-resistance circuit which is controlled by the illumination controller. The final ground for both the combination switch and the illumination controller is Ground G302, located under the center console.
Dec 23, 2011 | 2001 Isuzu Rodeo
No odometer light, circuit?
I own a 2000 impala ls and encountered the same problem.My solution to my problem was buy a new light switch and it worked.The circuits on the old one seemed to be burned so thats why they would come on sometimes.To install the new switch you need to remove the faceplate on the dash board and behind it you will find two screws holding it in place remove the screws and unplug the switch and replace.
Apr 18, 2009 | 2000 Chevrolet Impala
Message system reads "engine system maintenance required"
WHAT HAPPENED IS WHEN YOU SHUT DOWN AND RESTARTED YOU (RESET THE ENGINE MANAGEMENT COMPUTER) AND THE SERVICE LIGHT SHOULD GO OUT AFTER 10 MINUTES OF DRIVING
Mar 16, 2009 | 2003 Volvo S40
Light for odometer/compass/outside temp doesn't work
I CAN REPAIR THIS PROBLEM WITH 2004-2008 FORD F150 ODOMETER COMPASS OUT I WILL REPAIR FOR $125.00
BRIAN'S SPEEDOMETER @479-652-2258
Feb 19, 2009 | 2005 Ford F-150
Car Audio & Video Logo
62 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
