Question about NEC Dterm DTP 16D-1 Corded Phone
Whether its compatible with Vonage service - NEC Dterm DTP 16D-1 Corded Phone
  • 63 Answers
Yes
Posted on Feb 07, 2009
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Belkin Computers & Internet
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Dec 02, 2008 | Lands Phones
Phillips faxjet connecting to vonage telephone service
Fax machines are ANALOG devices. Vonage is a DIGITAL phone system.
Oct 22, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Hooking up Vonage to Time Warner Roadrunner(dsl): Do I have to buy a Linksys Wireless device for my Vonage to work?
You just need a router. and then plug the vonage device onto the router.
Note: make sure you have internet with the router before pluggin the vonage device to it.
Aug 15, 2008 | Linksys Wireless-G Broadband Router
Vonage ip voice will not work with internal firewall turned on
then iot seems that your fire wall is not compatible with it, try installing a different one, or try port forwarding that will fix your problem
Aug 15, 2008 | Arris SURFboard SBG900 Wireless Router...
NEC Dterm DTP 16D-1 Corded Phone Logo
18 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
