Max speed cpu i can use in a ax4bg2 - Computers & Internet
  • 2,404 Answers
Pentium 4 2.4GHz is the fastest processor that you can use according to the manual.
Posted on Feb 02, 2009
What is the role of a high speed CPU in Mono Laser Printers?
it is to transfer the document to the ink system ready for print
Dec 23, 2012 | Brother HL-5340D High-Speed Laser Printer...
How do I control CPU fan speed on an Acer G45T/G43T-AM3?
Some gamer or extreme motherboards have this feature, but I doubt ACER does. Try blowing out dust with canned air. This really works for me. I have an older machine, and I live in dusty Vegas so I know what you mean.
The other solution is to look for a bigger and quieter heatsink / fan.
Oct 25, 2012 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I have Hp Compaq nc6220 it works on battery with good speed but when i plug in adapter it works very slow
The only thing I can think of that would do that is if the power setting are messed up. There are different levels of power settings you can choose. Normally on the battery it runs the CPU slower, the screen less bright and so on to save power and make the battery last. It almost sounds like the full power mode or the adaptor mode is using the battery or extended power settings.
What you can do is look under control panel for the power settings icon or right click on the battery or the power plug by the clock and then adjust properties. Look for the tab or pull down that says A/C power or Full power or something like that. Then you need to go to the settings section for the cpu and cooling. Those are the two that have to be adjusted together. Depending on the software controlling you will either see a min/max setting or something that says cpu speed. Just adjust the max to 100% or set the cpu to variable. You can set it to max but that runs fast all the time and is noisier than it needs to be as the fans will always be running harder. And double check that the cooling settings are set to variable as well. Once you save or apply the settings your laptop should be much faster. There is a chance there is a setting in the system bios that is set to slow cpu but that is supposed to be over ridden by the windows software.
Anyway thats about the only thing that I can think of that would do this.Once you get the speed sorted out you can use the same panel to tweak the battery portion to run slower and not use as much power. If the cpu is allowed to speed up and down it only uses more power when you run more so it can slow down when its not needed. Think of this just like a car going up and down a hill. Power to go up then coasts down.
Oct 16, 2010 | HP Compaq nc6220 Notebook
Hello , my server mainboards fsb is stuck at 100mhz , the board can support to 133mhz , but i cant set that speed in the bios , the settings are greyed out. my cpu supports a max speed to 1500mhz but now...
It sounds like the system is set to "auto" at the moment, OR the memory speed will not support the 133mhz fsb speed, check the RAM and see what the speed rating is. Leave the CPU multiplier alone, that may well damage the cpu.
Mar 30, 2010 | Matsonic MS8137C Motherboard
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Bus ram TEAM 512 bus 333 fo T2341 Emachines
The max memory speed you can run in the T2341 motherboard is PC2100 = 266MHz memory. You can see the specs here at this link; http://reviews.cnet.com/desktops/emachines-t2341/4507-3118_7-30464489.html?hhTest=1
The max bus speed is 266MHz & memory bus is also 266MHz.
The bios dropped your current memory speed down to what it could handle for incompatible memory. In your case its running the memory at 133MHz. Replace your memory with PC2100- DDR266 DIMM's. (Like these; http://www.memoryx.net/ememt2me12.html ).
Mike
Aug 23, 2008 | EliteGroup L7VMM2 Motherboard
Acer aspire 3050 (XP2) - cpu speed nearly always about 800 mhz (1/2 speed) even tho settings are for max speed etc
I fixed this problem by uninstalling the Acer management suite, everything much faster now and the operating system has facilities for changing everything you need to anyway.
Jul 24, 2008 | Acer Computers & Internet
Computers & Internet Logo
430 people viewed this question
David Payne
David Payne
