Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Lost power when installing vista BOOTMRG IS MISSING
When i was installing vista i lost power due to a bad surge protector. when i tried again to install bootmgr is missing showed up now i can not do anything no other O/S on hard drive what can I do?
  • 565 Answers
Put your vista installation dvd back in the drive and run the repair utility. For complete details see:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
From the "install windows" box, click on "repair your computer", from the "system recovery options" select "startup repair".
If that doesn't work, try the "completePCRestore" option in the "system recovery options" box.
Posted on Feb 02, 2009
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
Lost our power and now it won't turn on.
Yes , usually you will need the manual to know how to replace it
In my experience the fuse blow due to something that is electrically faulty in the unit and changing the fuse does not remedy the issue. You may have a power supply issue that a reputable service tech will have to determine if it is malfunctioning in this area.
Jun 18, 2010 | Lexmark X2500 All-In-One Printer
My desktop dont come on
1) Check THE receptacle in the surge protector the computer is plugged into.
I have found more than once that One bad receptacle in the surge protector is bad.
"Hmmm, surge protector power on light is lit." "Monitor has power, amp for the speakers has power, and the router has power."
All plugged in to the same surge protector.
Tried a table lamp into the receptacle the computer was plugged into, Nothing.
Replace surge protector.
2) Bypass the Soft Power On of the Power Supply, and see if the problem is the Power On switch, or the Power Supply.
If you bypass the Soft Power On of the Power Supply, and the Power Supply comes on, the problem is a bad Power On switch.
If you bypass the Soft Power On of the Power Supply, and the Power Supply does Not come on, the problem is the Power Supply.
If you wish to know how to perform this simple test, just state so in a Comment.
(Believe upper right of your page)
Jun 17, 2010 | E-Machines eMachines Desktop PC
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Gateway Ml3706 wont boot up BOOTMRG missing . runs on vista
Are you using Windows Vista? You can fix this problem bt using your installation dvd. After the first couple of scrrens, you will get an option to REPAIR the installation. You should get a functioning system after that.
May 19, 2009 | Gateway ML3706 Notebook
Surge Protector
Surge Protectors are devices that usually you plug your equipment to.. and it protects it from Voltage Spikes that would otherwise destroy the device without it.. saddly not all Surge Protectors are the sam.. some are completely useless..
If you are really serious about protecting your PC not just the hardware but also the data and your work.. might as well invest on a UPS(Uninterrupted Power Supply) unit.. it has everything a surge protector can offer and more..
Apr 28, 2008 | MSI 845E Max2 LR Motherboard
Bootmrg missing
- Get your Vista installation DVD and pop it into your drive.
- Then restart your computer.
- Set your computer to boot from DVD or CD in your BIOS.
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista or repair your existing installation.
Select Repair. After which Vista's System Recovery Tool will start.
Select Startup Repair and let Vista do its thing! That really is all there is to it!
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Apr 23, 2008 | Microsoft Office Outlook 2003 for PC
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
94 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
