Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Bars on tape playback
Went from solid grey bars to color digital bars. on all tapes new and old. cleaned heads and still same problem even worse. do i need to bring it to the Dr.? thanks
    Problem Solver:
  • 7 Answers
I would first try testing it out with Sony tapes first. If the problem persist, then it needs to go in for repair.
Posted on Sep 08, 2009
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Colored, pixilated bars appear during playback
It is very common when the magnetic heads got dirty. Buy a Mini DV cleaning tape, follow the instruction clean the heads by playing the cleaning tape for a while. Record NEW video and playback to test.
Please know if you play the old video recorded buy the dirty heads, you may not get clear picture, because here is not correct data recorded on the tape.
Apr 09, 2009 | Canon ZR90 Mini DV Digital Camcorder
Sony playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
May 31, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Feb 09, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
4-5 Grey Lines appearing in the Playback Mode when playing tape
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Oct 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Jul 16, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
257 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
