My son sprayed our tv with a fine mist. I wiped it up once I noticed it, bit now hours later there's blackish grey streeks on the screen when I turn it on. I assume it's mosture inside the TV.. how can I fix this before hubby comes home?
  • enchanted_ph Feb 02, 2009
    Thanks for the advice... the problem is the tv is huge and I can't move it myslef, there's no way I can clean it. Ah well hopefully he'll realise it's just a tv and not freak out too badly? I mean it's not broken right?
    Genius:
  • 1,199 Answers
Ok you have to unscrew the screws on the upper backpanal of the tv to access the inside of the screen(be carefull yhe mirror is connected to this panal!) one back is off wipe and c;ean inside of screen and wile its open you might as well clean the mirror and the lenses too! you will notice a better picture! now just screw panal back into place and your done! dont be scared its not hard to do at all! Now you better move it before you husband gets home!
Please rate my response!
thank you!
Posted on Feb 02, 2009
My son took a baby wipe to the LCD tv screen and now there is a purple streak I tried a damp soft cloth but that didn't work any suggestions how to clean the baby wipe off?
Try a 50/50 solution of water/rubbing alcohol and a micofiber cloth. DO NOT SPRAY THE SOLUTION ON THE SCREEN ITSELF but on the cloth then wipe down the screen. I hope the screen isn't damaged !!!
Sep 22, 2012 | Televison & Video
Cleaning screen for flat screen tv
The only safe way to clean a flat screen is to use a microfiber cloth. Use the cloth alone on the television screen but if there are resistant stains lightly mist the cloth (not the television screen but the microfiber cloth) with water from a spray bottle. Try wiping across the television with the slightly dampened cloth and wiping back over it with a dry microfiber cloth. Even when the screen cleaning kits say they do not contain alcohol and that they are safe if it turns out that there was accidentally a wrong ingredient added to the mixture it is too late to do anything once it has been applied. The screen would just be messed up, and warranties don't cover that.
May 07, 2011 | Televison & Video
How do I hook up my Kirby Ultimate G for upholstery shampooing?
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Sep 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Moisture inside TV
Sorry to say the info I was given here didn't prove as useful as I'd hoped. Thank you however to those who tried!!! I called a TV repair man and spoke to someone in person, this was much more useful.
Feb 02, 2009 | Televison & Video
Shadows on screen
use windex it should get the job done but spray on rag do not spray tv screen
Jan 11, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Engine light flashing
in a dark area/at night, take a spray bottle w/water and mist the engine all around the cap,coil,wires. watch for arching,flashing.
Oct 17, 2008 | 1997 Mazda Protege
Vertical Grey Lines- WD 52327
Good Day, sara926;
Suspect the Light Engine part # 939P977010. This is an expensive item. So, I would suggest that that contact the manufacture and asked them if could give a concession for this; part and labor. They may not give labor but most times they will give you the part.
Good Luck, Big Irish.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Got wet
Most likely he sprayed the screen, and the fluid dripped down onto the board where the pushbuttons are. The pushbuttons them became contaminated and shorted out inside. Usually, the damage done will not be reversed by drying the set out. He should not feel bad, though, because we see adults doing that all the time. The TV has not "had it", since it is quite easy to correct. The board should be cleaned and any defective pushbuttons replaced by a qualified tech.
Aug 23, 2007 | Sharp 32F640 32" TV
Televison & Video Logo
Top Televison & Video Experts
