Question about Roper FEP320 Electric Kitchen Range
No matter what setting we put the burners on they get hot
We have an electric cooktop and we can't adjust the heat of the coils, no matter what setting we put them on they just stay red hot,
  • 370 Answers
Your burner switches have gone bad. usually not all go bad at once but one could ahve shorted out and burnt the rest of them up. This will be a pretty costly fix. But you can do it. You can order parts via model number on sears.com
Posted on Feb 09, 2009
I have a Better Chef model # IM-335 and the heating element just went bad. Is there a place I can get a new one?
apparently not. They are $31 new.
1500W Burners Hot Plates eBay
better chef model im 335 spare parts Google Search
Better Chef IM-302DB Stainless Steel Dual Electric Burner - Free ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates
Rating: 4.5 - ‎17 reviews - ‎US$38.75 - ‎In stock
Shop for Better Chef IM-302DB Stainless Steel Dual Electric Burner. ... Stainless steel brush finish; Dual self-cleaning coiled heating plate; Safety on/off switch; Adjustable temperature thermostat control; Indicator ... Model Number, IM-302DB.Missing: 335
Better Chef Dual-element Electric Countertop Range - Free Shipping ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates Rating: 4.4 - ‎30 reviews - ‎US$30.99 - ‎In stock
Shop for Better Chef Dual-element Electric Countertop Range. Free Shipping on ... This countertop range features 1,500-watts of total power and adjustable heating controls. 1500-watts total ... Model Number, IM-306DB. Country of Origin ...Missing: 335
Jun 04, 2018 | Dryers
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Electric Burners Turn On, Off, On, Off
the burners are halagen they are supposed to work that way but dont use them without a pan on them to reflect the heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. DECU165 Electric Cooktop
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Roper FEP320 Electric Kitchen Range Logo
88 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
