Question about HP Pavilion a705w PC Desktop
BLINKING POWER LIGHT
I have an HP Compaq 6710b. The power led on the front blinks steady when on battery use, but led stays lit when power cord is plugged in. After shutting down and unplugging everything, my led blinks steady and if I try to start up my laptop, the windows starts up but then freezes on the black screen. The unit will not start up properlly until I use the power cord. Ater using the power cord i can then unplugger the power cord and use battery power. I tried replacing the battery but this problem persists. This is an intermittant problem I've had since we bought the unit. Is there a quick fix or should I just return it for a new one.
  • Anonymous Mar 28, 2014
    When I plug in the power cord the green light in the back comes on and stays green. then the tower tries to boot up but will last 2- 3 seconds before it shuts down. Then in about 5-6 seconds it will try to re-boot but fails and ***** back down within 2-3 seconds. It doesn't stop until i unplug it. Any Suggestions?
  • 1,602 Answers
HOW MANY TIMES DOE IT BLINK
BLINK: SHORT-LONG-BOTH-MIX
EXAMPLE: 1 LONG BLINK AND 1 FAST BLINK IS A VEDIO AND MY ALSO BE A BOIS ERROR TOO.
THE LONG LIGHT MAY MEAN A POWER ISSUES, FAULTY WIRE, FUALITY POWER SUPPLY, INTERMITTING POWER SIGNAL TO THE COMPUTER SYSTEM
3-1-2- HARD DRIVE DMA ERROR
ROD
Posted on Feb 02, 2009
  • 596 Answers
When you restart your notebook do you have a blinking cursor when the system freezes? It sounds like you need to reset your BIOS. To do this, power off then on your unit, Press F10 to enter BIOS settings, and then F9 to reset the BIOS to default settings. (Your functions may be a little different but you can read your menu to see which function key to select.) Once this done, select "Save and Exit BIOS" This should get you going. As for the blinking light, sometimes this happens when the battery is not holding a charge. If your battery is new, try the BIOS reset first and comment on your results. I can guide you through the battery reset process, if needed. Good Luck.
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Blinking heart beat led blinking
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/compaq-presario-cq40533tx-lcd-inverter-p-2632.html
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
HP Pavilion a705w PC Desktop Logo
1,149 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
