Question about LG LSC183VMA Split System Air Conditioner
LG ac M483CS not cooling
It's a multi-split unit, 2 are 12,000 BTU's and one 24,000 BTU's, the 24k BTU is working perfectly, but, the other two have the same compressor and they doesn't get to cool...when i turn on any of the 12k BTU intdoor unit the power led begins to flash, it flashes two times an then is off for about 3 seconds andthen flashes again teo more times and it stays doing it all the time the in-d unit is turn on,t he indoor unit fan is working but the compressor doesn't, i believe that a contactor is not working properly because, if i disconnect the PCB of the outdoor unit while it is connected to the power and the 3 in-d units are turned off, one of the contactors returns to it's off position and then if i turn on any of the not cooling in-d units they will work and cool properly for a couple of months...it's the contactor broken or i will need to replace the PCB...i hope the contactor is broken...
  • Ken Bledsoe May 11, 2010
    Sounds like the board is bad. When you say it runs for couple of months normal. If the contactor was bad it would not work at all.
  • 400 Answers
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Posted on Mar 04, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
What is the corrective action for error code 46?
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jun 23, 2015 | LG Art Cool LA240HSV 22,000 BTU SingZone...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
LG LSC183VMA Split System Air Conditioner Logo
438 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
