Question about Philips SA3025/37 Flash MP3 Player
I try to download songs, but AutoPlay keeps popping up.
I plug the USB cable in the computer, and it AutoPlay pops up; which it usually does when you put something in the USB port, or put a CD in. But it keeps popping up and closing like the cable is being plugged in then unplugged...Someone help, PLEASE!!
  • 8,596 Answers
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
It is a Seagate GoFlex 2 terrabyte external connected through usb. I have dropped it several times and plugged it back in and it has worked. This last time it did not work when I plugged it back in. It...
I don't think so you have described properly your problem.
1. USB cable to Casing its completely a USB Device/Drive so where you plugged it?
2. "The Laptop does not see the drive or the USB adapter when its plugged in" you mean BIOS?
3. Windows 7 Pop Up Autoplay window what opens when you try to open it?
May 15, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
When i plug my ipod touch to the computer an autoplay window pops up asking if i want in import pictures but itunes doesn't recongize my ipod so i can't get the songs to download to my ipod. how do i fix...
I am inclined to suggest using a proper browser, but that wouldn't be right, would it.
Try using Googles Picasso3. It works for me, which is more than anything else.
Dec 13, 2010 | Computers & Internet
How to get Photos From memory card to computer
  1. Hi
  2. Plug your Samsung mobile phone's USB flash cable into the phone and into the computer's 2.0 USB port outlet. When the computer detects a USB connection, a notification screen will appear in the lower right corner of the screen, above the task bar. The phone's software driver will be automatically installed to your computer's hard drive.
  1. Import your pictures to your computer. Click on "Import Pictures" when the "AutoPlay" dialog window pops up. Close the "AutoPlay" window to configure the import settings.
  2. Choose a gallery title for the pictures you are importing. When the blank data form appears in the bottom right corner of the screen, type a name for your gallery in the data form. Click on the "Import" button to begin the downloading process.
  3. Remove the Samsung USB flash cable from the computer and then from the mobile phone. Click on the "Start" menu icon, then select the "Pictures" tab folder. Your newly imported pictures should be stored in this folder. Please Rate this solution. Regards.
Nov 12, 2010 | Samsung Cell Phones
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
How to install pc suite for windows xp ( nokia 5310)
To install the PC Suite with Windows® XP If you use Windows® XP on your computer, you may need to install two hot fixes on your computer to use your phone with the PC Suite. If so, the PC Suite will ask you to install the Microsoft® software hot fixes during the installation. To install the hot fixes for Windows® XP:
  1. Connect the USB cable to the computer and the phone.
  2. On the phone: When you attach the USB cable to the phone, a USB connection window appears. Select PC Suite.
  3. On the computer: Click PC Suite on the autoplay pop-up to start the installation. If no autoplay pop-up appears, see the instructions below to access the installation software drivers.
  4. In PC Suite, click on the first hot fix (KB943198), which re-directs you to the Microsoft® support site to download the hot fix.
    URL: http://www.microsoft.com/downloads/details.aspx?FamilyID=f2f0a7c2-3b44-4d2e-9640-e0d21818763e&DisplayLang=en
    Note:Before you download, make sure that you choose the same language for the hot fix that is set on your Windows® XP language settings.
  5. Follow the installation instructions.
    Note: The computer may restart after the first hot fix is installed.
  6. Return to PC Suite and click the second hot fix (KB945436), which re-directs you to the Microsoft® support site.
    URL: http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=945436&kbln=en-us
  7. Request the fix to be e-mailed to you and enter your e-mail address.
  8. Go to your e-mail client and open the e-mail. Click the link to the hot fix.
  9. Click Run to the File Download pop-up.
  10. Unpack the attached protected zip file. Click Ok to Microsoft Self-Extractor or select a source.
  11. Use the provided password included in the e-mail.
  12. Open the downloaded hot fix and follow the installation instructions that appear.
Note: If you run Windows® Vista, this problem installing PC Suite will not occur.
The drivers for the installation files are located on your memory card. The first time you connect your phone to a computer with a USB cable, a pop-up is often automatically shown on the computer.
To access the installation software drivers for PC Companion, PC Suite or Media Go:
  2. On the phone: When you attach the USB cable to the phone, a USB connection window appears. Select Mass storage.
  3. On the computer: Click My Computer > PHONE CARD/Sony Ericsson PC Software > pccompanion > Startme.
  4. The PC starts to initiate the PC software installation. Follow the installation instructions that appear.
  5. When installation is complete, Sony Ericsson PC Companion will start.
Note: During installation, several pop-ups may appear about Device driver installation or trusted software. Click Yes/Continue/Next to finalise the installation.
Jul 07, 2010 | Ahead Software Computers & Internet
How do i download songs on to my mp4? when i plug in my USB cable nopthing pops up therefor i can not download any songs on to it.
Make sure your USB port is working good and make sure you have firmly connected it. See if it comes up in my computer. Let me know what happens.
Jun 13, 2009 | Samsung Yepp YP-T7JX MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Downloading music from computer
easy. plug in the USB cable into your PSP and the other (big) end into your computer. on the PSP home menu, go all the way to the right and select USB mode. YOU NEED A MEMORY CARD INSERTED. click open and explore files if somthing pops up on your computer. if not, go to my computer, then memory stick K (or what ever letter your compute shows). then if its not already there, make a new folder and call it MUSIC
then drag and drop / copy and paste your songs into that folder.
Nov 18, 2007 | Sony PlayStation Portable (PSP) Console
Philips SA3025/37 Flash MP3 Player Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
