Question about Philips 32PFL7332D 32 in. LCD HDTV
I have some how erased channel 3/4 on my sony tv KV-1970R
Please advise me how to get it back so i can hook my cable tv back to it??? a reverend in diser straits.
  • 716 Answers
Select Channels in the Installation menu. Use the cursor to enter the Channels menu.Then Autoprogram in the Channels menu.
Use the cursor to enter the Autoprogram menu.
Press the ok button and Select Cable in the Installation mode.
the TV will detect cable company supplied signals
and will search for cable TV channels.
Make sure that cable TV connection of equipment is completed.
Next Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed. The progress bar indicates the number of analog and digital TV channels found.
When Autoprogramming is complete, a message appears confirming the completion. Press the red button "Finish" and the TV returns to the Installation menu.
This Is A Summary From Exactly What It Says In The Manual To Program Channels.
Posted on Feb 02, 2009
  • Michael Fisher
    Michael Fisher Feb 02, 2009
    Go To Channel 3 or 4 and hit the green color button to manually reinstall the channel.
    Also If You Want Your Manual It Can Be Downloaded Here
    Sergeant:
    Champion:
  • 239 Answers
Do a autoscan it will get those channels back>
    President:
  • 1,990 Answers
Welcome to Fixya! You can go into the Settings and the Scan Menu should have a Manual Setting. Go into the Manual Setting and Reenter the 3 and 4 Channels. Scanning will not Pick up these Channels as they are Not Active Stations on the Network. Please Rate My Response! Thanks!
    President:
  • 1,214 Answers
There should be a Menu button available on the TV. Go there and select the program to rescan channels.
It is also possible that the TV will automatically recognize the cable box channel once connected to the TV and turned on.
Reply what you find and I will help you further.
  • Mark Egan Feb 02, 2009
    You can download the manual from the website also. It describes how to set up AutoProgram, but I basically described it in my original post.
Want to hook up cable cant get channel 3 i bought a universal rem
Take the cable and screw it in the if connecter in the back of tv. Providing they have connecter on them.hope this helps you some.
Mar 01, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Trying to hook up Phillips DVD player and have 3 coaxial cables that need to be hooked into Sony TV and I have 14 holes for cables-help!
Don't use co-axial cables buy HQ SCART Gold Plated Ribbon cables with full 21pins then hook up the AV out of the DVD player into one of the AV in on the TV.
When you turn your player on it will autoselect the correct AV (audio visual) channel on the TV.
Feb 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony c450 will not work with new 46" Samsung TV using compodent 3
are you sure that the channel your tv is on matches the name on the inputs where you plugged the component cables in? Channel surf-maybe start at 2 and go down and that is where those input channels should be.
Sep 01, 2009 | Sony DAV-C450 System
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
CHANNEL ERASED
go to menu atuoprogramming will automatically lock in every channel that you receive a signal from.
Dec 11, 2008 | Televison & Video
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Philips 32PFL7332D 32 in. LCD HDTV Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
