Question about Toshiba Satellite A105 Notebook
Toshiba wont charge
I had a bad power cord that I had to play with in order for it to charge. Finally I guess it finally shorted out. So I brought a new cord and when I pluged it up all I got was the battery light blinking blue real fast. Not sure if I have wrong power cord or if something burned out.
  • Anonymous Feb 02, 2009
    This is a big problem w/ the toshiba notebook.. It happened to mine while on warranty and they fixed it, but it started again right afterwards and went completely out as soon as warranty expired. Toshiba ought to take care of this. Anyway, I found a guy online that explains the problem and how to fix it. Try this link. Good luck. http://www.laptoprepair101.com/laptop/20...
  • 596 Answers
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Posted on Feb 02, 2009
It was playing perfectly fine when I got it, but it has finally died and it won't charge
I am not familiar with this particular product on how to do it but I am sure this is a bad battery. If you can get it open I am sure you can fix it.
Feb 12, 2013 | Audio Players & Recorders
Motorola triumph won't charge when plugged in
I tried everything, bought 3 new batteries, 4 new chargers and everytime about a day goes by and the phone dies in less then 3 hrs and stays dead...tried connecting to usb, tried removing the batter and still dead...finally followed the steps on the website: https://motorola-global-portal.custhelp.com/app/answers/prod_detail/a_id/83322/p/30,6720,8064 first I held down the power and lower volume buttons for 10 sec. and no luck, removed the sd card followed by downloading the manager and motocast from the website above and finally...looks like the charge light finally turned back on...Finally guess this is what it needs with all the downloads and memory used i need to keep it up to date....I guess...hope this helps others...i was ready to tear this phone apart and just buy a new one...just saved some $$
Jul 27, 2012 | Motorola Mobility Triumph WX435 Cellular...
How can i repair the power cord plug slot on my toshiba laptop it wont charge it?
First check voltage, using a meter, at the plug coming from the adapter. If all is well, then you have to tear the laptop apart piece by piece to get to the wiring of the plug. If you finally get there, look for broken wires, burn marks, etc.. If the cord is good, plug it in while torn apart and check voltages where the wire solders into the motherboard. If something is amiss, there's a bad wire that needs replaced. If you're still having problems, and feel adventurous, retouch the solder connections on the mainboard where the wires from the power plug connect to. If it still isn't charging, it might be a bad battery or motherboard. Either way, it's not that easy to fix (except for getting a replacement battery)
Sep 26, 2010 | Computers & Internet
Toshiba satellite P205-S6287 the power button
Make sure the battery has a full charge, and that it's plugged into a wall socket, then try the power button. You will get the same symptoms as a bad power switch if your battery power is very low. Other than that, the battery could be bad, or going bad. If the problem is a faulty power switch, you will have to have it replaced.
Mar 12, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Laptop not charging
Double check and make sure that the AC power cord is ok and that it's firmly connected to the laptop. Also check and make sure the cord or part that goes into the AC adapter converter is plugged all the way in. Finally, most laptops will have some sort of a "Plugged in" indicator or LED light on the laptop indicating that it's plugged into 120V AC. If you seen nothing like this, then it is most likely the power cord. If your battery is bad or was going bad, the laptop should still work when plugged in. Finally, make sure that your battery is firmly seated into the laptop. Some laptops will not function when there is no battery, even when plugged in. If you determine that either the battery or plug is defective, of course, you can order a replacement online or from the manufacturer. You can also try EBAY for better prices.
I Can Fix It
Aug 18, 2009 | Apple 13 MacBook Notebook Computer ...
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
Power failure
your safest bet is to replace the power cord with a new one you can short circuit your computer if the expose wire touches while its plug in just find a pc store that sell the power cord for your pc
Dec 04, 2008 | Acer Aspire 5050-3242 Notebook
Battery not charging...
My impression is that you might have a defective cord if you still have your old adapter and has the same power specification try this first.
If the battery is hot and does not charge you might have a defective battery . Better have it checked at the service center before buying a brand new battery
Jun 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A105 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
