Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have no 'input selection' on my Sharp HDTV 37", model LC37DW99U
I did click on reset to factory settings by accident and wondered if this is my problem?
  • harriettcamp Feb 04, 2009
    You're going to flip about this one.... .I figured out the problem, the cable connection to the back of the TV had became loose and whenever I unscrewed it from the TV, the end fell off. I replaced the cable and I now have my channels back.
  • jimfraser Feb 14, 2009
    I cannot select input source 1 or 2 on my Sharp LC-52D64U, I'm trying reconnect my VCR.
  • 11,896 Answers
On your menu, go to the channel settings. Go to add/delete channel. You will have to add this channel manualy. The tv might have went into autoprogram mode and deleted it.
Posted on Feb 02, 2009
  • Nate Stansfield
    Nate Stansfield Feb 04, 2009
    WHAT! That is so good to hear. I love an easy cheap fix. Good Job!
Internal or external speaker selection does not show
Do a factory reset to this set. To do it, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Mar 21, 2014 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Forgotten password for sharp tv model #LC-19SB25U
Its in the user's manual. Press menu, setup and find 'reset' to factory settings. It will require inputting all changes you made...
Dec 27, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp aquos 37" has picture but no sound ? unplugged and changed audio back to factory settings still no sound? is there a fuse some were for the sound card ?
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case for my LC-32D6U.
Jun 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hannspee 37 in lcd tv xv-s Both hdtv report no signal They where working I have tried both a Hd Sat box /Xbox and three new connection leads to no avail Went through the menu Setup and Reset modes no joy...
There is a hidden menu. Press the "MENU" key and then press "991". You now see a new menu labeled "Factory". One of the settings is: EEPROM Init. Selecting this supposedly resets your television and erases almost everything you've set... so don't do this casually. And don't press anything until it is done. I'm actually afraid to try this since my set works. If this fries your set, you're on your own.
Mar 17, 2009 | Hannspree XV37 HDTV 37 in. LCD TV
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
I have no color on my 37 aquos sharp lcd
Give more info. In tuner mode, in component,rca or s-video input?
Dec 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,097 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
