Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound coming out of my Aquos Sharp HDTV-LCD
I am having trouble with no sound coming out of the tv. I purchased this tv through shopnbc 2 years ago. What can I do?
  • Anonymous Feb 04, 2009
    No sound from TV some times it would come on if I turned the TV off and on now it is off all the time.
    Can any one help
    **** Richmond VA
1Guru
  • 61 Answers
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Posted on Dec 12, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 33 Answers
SOURCE: Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Posted on Feb 19, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 8457 Answers
SOURCE: Cracked Sharp LC-46D62U lcd panel.
look up your local repairman they should have part.The part it should cost about $150,labor must ask.
Posted on Jul 01, 2009
Samsung LED TV, sound but no picture
Have you tried unplugging it and letting it reboot?
Nov 12, 2016 | Samsung Televison & Video
Sound
I can suggest you to bring this to any TV repair center near you because I believe they repair any brands like in my place sicen this unit of yours is just a generic type of a television set and ShopNBC only has a limited 1 year warranty for this and this one really has alot of problem and complaints from other user...
Good luck.....
Jul 04, 2008 | Protron PLTV-32 Television
I have sound, but no picture. No previous signs of malfunction. What could be wrong?
Did you check trouble shooting section in manual? Is your TV hooked up to a home theater system? Then check power source to TV. If ok , then I would suspect the lamp blew out.
Dec 03, 2014 | Shopnbc VIZIO Gallevia 46" 1080p LCD TV HD...
I have no color & the sound is very crackling. It was purchased from ShopNBC in 2005.
May I have the model no of the tv so that I can tell you what the problem is?
Oct 17, 2010 | Protron Televison & Video
Hi, we purchased our Vizio about 3 years ago and had trouble right from the start however we cannot locate the receipt. The problem is when we turn the TV on it runs for about 4 to 5 minutes then we loose...
Yes,this problems is the 1 or 2 long LCD inverter boards are dead.Replaced these 1 or 2 long LCD inverter boards,will solved this problems.These long LCD inverter boards help the LCD screen have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Sep 08, 2010 | Vizio VW32L 32 in. LCD HDTV
Bought this Russian Diver 7003 from ShopNBC about 2
Hard to fix for people without watchmaking knowledge. I'd do that in 15 minutes. Anyway - Invicta is NOT even the average quality watch company, so, can NOT charge you more than price of watch. Contact me: artkalnins@yahoo.co.uk This will be long explanation, but , hopefully you will get it right.
Mar 05, 2010 | Invicta RUSSIAN DIVER GMT WATCH WHITE DIAL...
Protron ac adapter
Part on back order from manufacturer phone is 888 257 8899 they dont take orders... u have to keep calling... its been on BO for a long time
Sep 12, 2007 | Protron PLTV-32 Television
Protron 32"
Hello, I have a Protron 32 in. TV also. After about a month I saw a few lines verticle on the screen. I called Protron and they were very nice and said thet would send me instructions and a pick up notice for FedX. I received it in about a week. I packaged the tv up and sent it to them. I started calling after about a month and they stated they were waiting for the part to come in to fix it. This went on for about 4 months with me call in every week. Eack time thay would tell me it was going to be ship to me with in 2 weeks. After 4 months I called and was very vocal and stated that if I did not have my tv in 7 days and this was on Wednesday I was going to get on my PC and anybody that did any kind of search on tv's, Protron, Spectrum would know about my problems and how sorry the company was and hung up. The folling Monday I recieved a new tv and it was the newer mdl.I also told them I did not want a repaired tv that i had paid for a new one and would not settle for a repaired one. I have not had and trouble with this tv and it is about a year old. I hope you may be able to do the same thing.
Jul 08, 2007 | Protron PLTV-32 Television
Remote Not Working
what did you do ith the cable compay's remote?
Jun 24, 2007 | Protron PLTV-32 Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
52 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
