Question about Brother PC-6000 Pacesetter
Pacesetter by Brother PC-3000 sewing machine
A square button, that select stiches stoped working. The machine is only can do letters,but not zigzag nor other stiches.
SOURCE: stich 0, 1 , 2, and 3 don't work, the model is a
0,1,2 stopped working, everything else was fine. Needs a new panel keyboard. I had to take mine to the local sewing shop. Board $157, install another $50. Found a used board for $75 and same install $. Both new and used boards only come with a 60 day guarantee. I could get a new Brother 6000i machine for the fix price. I don't use the monogram much but I like this machine. I was told this is not a common problem.
Posted on Jan 12, 2010
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
  • 7 Answers
SOURCE: how do you thread a brother pacesetter 6000 for
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
Posted on May 06, 2009
  • 1116 Answers
SOURCE: appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Posted on Feb 21, 2010
  • 980 Answers
SOURCE: I have a brother pacesetter 607 model. It used to
Simple things first, check the needle to make sure it is perfect, if you can select all the patterns and the needle moves from side to side but does not pick up the thread then it could be a timing issue and you can email me for attachment of instructions, if the needle is not moving side to side when you select a pattern then it may well be a split camstack.
drivewithken@blueyonder.co.uk
Posted on Jul 05, 2010
I have a brother pacesetter 607 model. It used to work very good for years but lately its not sewing the zigzag or any other stitch other than the straight stitch. can you help please? Thanks.
Jul 05, 2010 | Brother 925D Serger
Appearence of loop and no zigzag stich on ls-2125i brother
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Stich 0, 1 , 2, and 3 don't work, the model is a 1999 pacesetter pc 3000
Dec 18, 2009 | Brother Sewing Machines
Brother ls2125 won't zigzag stitch
that sounds like a timing issue if it will pick up every now and then i would recommend taking it to a brother dealer for repair as timing is not easy to set
Jun 22, 2009 | White Sewing 915
We can not operate our brother Pacesetter sewing machine
A lot of time you can find a manual on ebay or sold through sewing supply stores. A quick search online showed that sew4less has the model manual for sale. Also if you contact brother or check their website you should be able to get a manual.
Oct 09, 2008 | Brother PC-6000 Pacesetter
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
598 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
