Question about Samsung CLP-510 Laser Printer
Samsung CLP 510 Imaging Unit
Recently purchased a Unit Imaging Transfer Roller unit; now I get a message that indicated the imaging unit needs replacing. Assume this is the drum located at the bottom of the unit. Do these two items normally go out at the same time? Why would it not indicate that I needed to replace both items. The cost of the two items may be prohibitive; just purchase a new HP printer for less cost???
  • LEGIONBR92 Feb 19, 2009
    SAMSUNG CLP 510COLOUR LASER PRINTER TELLS ME BOTH TRANSFER BELT AND IMAGING UNIT NEED REPLACING. I THINK THE TOTAL COST IS ABOUT 400 BUCKS. IS THIS REALLY WORTH IT
    Genius:
  • 2,120 Answers
The Imaging unit needs to be replaced when the drum fills up with waste toner. That's what triggers the message.
Posted on Feb 02, 2009
Why is there a vertical smudge from top to bottom of page?
  • Most likely there is a scratch on drum of imaging unit
  • or scratch or dust on transfer belt
  • or dust on LSU
Check all these , should get resolved.
Aug 26, 2015 | Samsung CLP-510 Laser Printer
Samsung CLP 510 just replaced transfer belts, imaging unit and fuser but now am getting what looks like wet spots on the prints
Some toner may have spilled in the printer. If so, you will need to clean it out. Also, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
Jul 20, 2010 | Samsung CLP-510 Laser Printer
Can you tell me how to replace the transfer belt imaging unit?
First you open the left side door, then press the button and lift the top cover, the transfer unit is the first on top with a handle and levers to release. The drum unit is under that also with blue levers to release.
Jan 12, 2010 | Samsung CLP-510 Laser Printer
My printer is asking me to replace the imaging unit, but i have no idea what it is?
This is a consumable some what liket toner. When its life ends you need to replaceit.
Imaging unit is greenish Organic Photoconductor. Made up of Aluminium with photo sensitive Coating.
Nov 29, 2009 | Samsung CLP-510 Laser Printer
Imaging unit needs replaces per message
Yes, but be careful about where and how you dump the toner. It can make a real mess!
Aug 22, 2009 | Samsung CLP-510 Laser Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
An
Aug 20, 2008 | Samsung CLP-550 Laser Printer
Error
I had this problem with my CLP-550, which is now 5 years old and is still on the starter toner cartridges. I found a solution at the following URL, where I at least found a picture of the imaging unit:
http://pcproblemi.blogspot.com/2008/08/replacing-imaging-unit-on-samsung-clp.html
It must have been a contact problem on my imaging unit, because all I did was remove the unit and put it back.
You need to open the toner casing and the duplex unit. Then open the top housing, exposing the imaging unit. Open the plastic retaining levers at front and back of the imaging unit, and just lift it out (not too far), and then put it back.
I then closed the whole thing and it again worked perfectly.
Hope this helps someone.
Jan 10, 2008 | Samsung CLP-550N Laser Printer
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Resetting the imaging unit
How do you reset the imaging unit?
Dec 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
975 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
