Question about JVC AV-27D302 27" TV
Sound I have the TV set up and brought it down to my college apartment, and the sound isn't working at all, not even white noise. I have pictures and everything, just no sound! Any ideas?
  • 55 Answers
First off check the obvious..see if a wire has come off the speaker. Next would be the audio driver. I'm not up on this model but you probably have an IC for the audio that handles the whole audio chain. Good luck.
Posted on Mar 09, 2009
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
Xbox 360 no sound or picture but with a twist
The towel trick is just that a TRICK. overheating your console
will shorten the life of most of the electrolytic capacitors.
and if it works it will very temporary.
First thing to try
goto gamestop and buy a multi a/v adpter .that will have
many plugs . plug the xbox 360 adapter in and then
plug the S-video into your set and some time you
can get video single from this line even if the main
Red /white/yellow/ line are dead . and since you have
sound from red /white you should be ok.
If the s-video has no output then your going to have
to do what's called an x clamp mod on it or
have a shop re-flow the G.P.U. this is the most
durable repair.
Any questions feel free to ask.
Rob
Feb 18, 2010 | Microsoft Xbox 360 Console
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
We have just brought a PDP-42XR8DA plasma tv, once set up and all tv stations working we went about trying to set our sanyo dvd player to the tv. Once all the inputs were in the right terminals and all...
Bad cable probably. As you are going through direct connection ie AV I would be looking at either the cable or more probably are you connect to the correct AV video out put from the DVD?
Jul 26, 2008 | Televison & Video
Toshiba 36A50 Noise Issue
your tv needs a tech the problem is in the IF circuit.good luck.
Apr 29, 2007 | Toshiba 36A50 36" TV
JVC AV-27D302 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
