Question about KitchenAid KUDS01DJ - Multiple Color Dishwasher
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
Hi - My kitchenaid dishwasher superba (kuds01fkss1) is "stuck" or clogged / jammed with (I think) a piece of glass. I noticed a broken coffee cup and glass that I can see has gotten into the strainer / motor area. I've taken off the arm and three screws holding down the strainer, but I cannot lift this assembly off to clean out the glass. The dishwasher turns on and goes thru the motions, and then stops and makes a humming noise, like something is impeding the spinning or motor. I'd like to try to fix it myself, but just can't get this assembly (strainer, etc. off). Thanks in advance.
  • 11,896 Answers
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Posted on Feb 02, 2009
Kitchenaid superba
Do the dishwasher still operate or not?
Feb 23, 2008 | KitchenAid 24 in. KUDU02FR Built-in...
I have a kitchenaide Superba Monterey 21, whisper quiet dishwasher that will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | KitchenAid Dishwashers
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
I have a kitchenaid superba dishwasher wont drain
does it make a buzzing sound when on pump? if so then the pump is trying but is either jammed or there is a blockage in the waste hose/outlet u bend. try seeing if there is a blockage in the waste hose first.
Mar 05, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
KitchenAid KUDS01DJ - Multiple Color Dishwasher Logo
1,472 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
