Kenmore 25901/25911 Washing Machine Not Spinning
A week or so ago, my machine was running and all of a sudden it got very LOUD when agitating. The machine would go through all the cycles and clean the clothes, but it was just very very loud. After a few days, the noise improved but yesterday, returned and I also smelled something kind of burning. Now, the agitator does not work at all. Is the problem so severe that it will cost me a significant amount of money to get it repaired? Please advise.
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore washing machine not spinning
Model #? Clutch has nothing to do with spin on older direct drive models Most likely a motor or timer problem.
Nov 11, 2017 | Kenmore Washing Machines
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
I have a kenmore model 20422991 washing machine it wont agitate spin or drain but i can here the motor running
Thanks for choosing FixYa and welcome. Your drive motor controls the spinning, agitation, and draining. Even though it is running, the transmission may be bad. Replace the motor drive if this is the case.
Apr 02, 2011 | Kenmore 22422 Top Load Washer
My washing machin suddenly stop while I was doing laundry when it gt fill with water
After water filled, the machine will enter agitation mode. It stopped since the mechanism to engage the agitation to one direction of motor turning is not engaged. It is a helix nut to lock in the direction of motor turning (motor has 2 direction : one is for agitating and the other is for spinning). It is worn out and needed replacement.
Sep 20, 2010 | Kenmore Washing Machines
My kenmore washer is no longer agitating or spinning.
if it is just your motor coupling broke i would replace it ,only 15 bucks
Feb 17, 2010 | Kenmore 22422 Top Load Washer
How do we fix a washing machine that does not spin?
Is it agitating? If so you may have a bad lid switch if it's not spinning or agitating you may have a bad drive coupler.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
207 people viewed this question
Top Washing Machines Experts
