Question about Intel D865GVHZ Motherboard
Boots when power on - Intel D865GVHZ Motherboard
  • Mike PP Feb 04, 2013
    Very funny! It's not supposed to boot when you power up the PSU. It does an autotest for a second and stays in stand by, waiting for pressing the power button on the case. I suppose it must be a mobo's capacitor that isn't charging quickly enough to enter in standby mode. It only happens when powering the PSU after a few minutes off. I've changed the PSU and had the same result. Unpluged all the devices including PCI NIC, front USB, HD and DVD. The video card and audio are onboard. Reseted the CMOS configurations, too. Nothing.
  • Michael Green Feb 05, 2013
    Now you have given the actual symptoms I can give you a possible cause. Check in the BIOS that the default fault condition for restart is not "Turn On" this can cause the computer to continue to try booting even if you turn the power off between, but as you have reset the BIOS, it may be the factory default setting. Go into the BIOS and set the restart condition to "OFF" this should cure the problem.
  • Intel Master
  • 3,799 Answers
That is how it is supposed to work. If it boots when the power is off, you will be rich.
Posted on Feb 04, 2013
SOURCE:
Digistream box stuck on boot
Power it off, leave for a couple of minutes and power on again. If still no boot, hdd error if recordable or power supply issue.
Jun 17, 2015 | Computers & Internet
How to fix my PC boot problem?
Try to boot into safe mode and run chkdsk /f from the command prompt...
Jan 11, 2015 | Microsoft Computers & Internet
No power light, smartphone does not boot at all.
There is a way to do a Master Reset on MOTO Q phones that cannot access the standard Master Reset method:
  1. Power off the Q
  2. Press and Hold the Center Select Key, while powering up the phone
    or
    Press and Hold the Z & E keys, while powering up the phone
  3. The MASTER RESET screen will appear
  4. Press Yes
  5. This will restore the phone to factory settings
Jul 03, 2013 | HTC Amaze 4G
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Screen shows "Reboot and select
what you want do is disconnect your hard drive then disconnect the power from your motherboard the from the power supply, and press the power button the connect all the power cables back then enter bios screen go to the boot tab and select boot device priority and move your hard drive up.
May 21, 2011 | Computers & Internet
Could you tell me what has to be done when the only item appearing on the screen is MC70?
Resetting the EDA
There are two reset functions, warm boot and cold boot. A warm boot restarts the EDA by closing all running
programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory card is not lost.
Perform a warm boot first. If the EDA still does not respond, perform a cold boot.
Performing a Warm Boot - Soft reset
Hold down the Power button for approximately five seconds. As soon as the EDA starts to boot release the Power button.
Performing a Cold Boot - Hard reset
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
Dec 03, 2010 | Zebra Symbol MC70 HandHeld Mobile Computer...
Mc70 handheld scanner won't boot up - no light, nothing.
Have you tried any of the steps below?
  • Warm Boot: Press and hold the Power Button for 5 seconds.
  • Cold Boot: Press the 1, 9 and Power (W, C and Power) buttons at the same time.
  • Clean Boot: Press the 1, 9, Power and Trigger (W, C, Power and Trigger) buttons at the same time.
Aug 31, 2010 | Symbol MC70
How to fix a motherboard that does not turn on at all.
Make sure there is power at the outlet, surge suppressor, power strip. Be sure any connected UPS is on. Try again.
Remove any recently installed hardware and go for boot. If the PC boots, check to make sure that the new hardware does not overload the old power supply - if it does, replace with a higher capacity power supply and go for boot.
Open the PC. Look for indication of power - LEDs, fan, etc. Replace the power cord between the outlet and computer if one is available, and go for boot.
If possible, obtain a power supply tester to determine if the power supply has failed. Replace any failed Power Supply and go for boot.
Disconnect power. Disconnect all non-required cables and accessories. Leave only the power and data cables for power supply, boot drive, video card, mouse, memory and keyboard connected - everything else should be removed (with the exception of the small cables that go to the MoBo headers for LEDs, and switches on the case). Everything means both data and power cables. All controller cards should be removed as well unless using on-board or built-in controllers. Reconnect power and try for Boot.
Add devices, cables, etc one at a time to determine which is causing the fault. A PC that boots and shuts down shortly after could be an indication of overheating / over load. Clean dirt & dust from case, ventilation slots, etc. Make sure all fans spin freely - replace any that do not.
Those are some things to start working on.. hopefully, you'll find the problem and not have to go further. Good luck!
Aug 25, 2010 | Asrock 775VM800 Motherboard
I plugged in the power cord and I get no power at all. No lights/nothing? Thanks.
HI
ITS PROBLEM OF COMPUTER SMPS (SWITCH MODE POWER SUPPLY) REPALCE IT ..
TNKS
RABBANEES
Nov 05, 2009 | Dell OptiPlex GX260 PC Desktop
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Intel D865GVHZ Motherboard Logo
14 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
