Question about Saeco Magic De Luxe Espresso Machine
Estro magic delux (now saeco i think) water leaks below brew unit
Instead of water coming into the tray beneath where the coffee comes out, it goes through the brew unit and comes out beneath the unit in a tray where excess coffee grinds shouldbe. the water tray is completely dry as if the water is being diverted through the brew unit.
much tnx.
  • Anonymous Feb 26, 2009
    Same here. It is noticeable because we have a wooden cutting board underneath the machine and there are now water stains on it. Also there is water seeping through under the removable unit inside.
  • Anonymous Mar 30, 2014
    goes thru all steps but no coffee comes out
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Posted on Mar 25, 2010
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Magic delux water leaks through brew unit
HI
I think this is your problem. Go to this link, because they won't let me post the solution. Say its to long. Copy and paste into your browser bar.
http://www.fixya.com/support/t3456314-leeks_coffee_into_grounds_container
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
384 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
