Question about Philips DVP3020 DVD Player
Philips DVP 3020 Wrongly set to Component
I have stupidly set the Video output to Component, and then pressed Ok, so it is now not showing anything on my TV, which is really old. Connected with SCART.
Can i somehow change this without seeing menue (Like switch on, Press root menu etc...) or factory rest it with some combination?
Tnx.
  • 50 Answers
Use the yellow composite plug to connect to your tv..this always gives out a signal..
Jay
Posted on Feb 21, 2009
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
Philips DVD player DVP3996 is giving wrong region error
Hello
To set your Philips DVP region free, do the folloing.
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press OK
Press "138931" and a popup screen will appear
Use the Up arrow key and select Region 0 for a region free DVD player
OK.
Apr 06, 2011 | Philips Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Mar 06, 2010 | Philips DVP3020 DVD Player
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
I did some stupid settings with progressive output. now the tv screen is blue and i can hear the DVD running. Menu is also not visible.
Put player in standby mode, Press 369 on DVD player remote, power up. This will turn off progressive mode.
May 26, 2009 | Sony DVP-NS67P DVD Player
Hi benimur
Appreciate the direct "Ask Me",.
There might be more than 1 version of this player depending on country of origin or intended marketing region hence the solution posted that you are referring to might not be applicable to your concern.
Offhand, I would suggest that you try a hard reset, that is unplug from the mains for an extended period of time (perhaps even overnight). The idea is to dissipate whatever residual power is inside the unit and hopefully thereafter, it will revert to factory defaults. Then try again. On the first power ON, wait till "NO DISC" is displayed, then try a known good disc. Alternately, you can also try, unplug, wait for a minute or so, press & hold the STOP button, plug the unit to the mains. You can also try that with the other buttons.
Should the above be not corrective, am afraid that the a firmware update/flash/reset is required by an authorized service center.
Hope that this be of initial help/idea. Pls post back how things turned up or should you n
Oct 12, 2008 | Televison & Video
Region codes
3020
Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for any region)
Aug 26, 2008 | Philips DVP5140 DVD Player
Philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Jul 29, 2008 | Philips DVP320 DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
Philips DVP3020 DVD Player Logo
340 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
